Not pretty, but I want it sorted once and for all...
#002 Steel String Singer - almost there
Re: #002 Steel String Singer - almost there
If everything is good up to the points where the red/green/white leads connect to the filters (but check that), then the problem must be within the R and C arrays and/or switches. There is no way the effect should be barely audible.
I've checked everything. I get the exact pf and resistance values on from common to the white or red board connection when I rotate the switch.martin manning wrote: ↑Mon Mar 11, 2024 1:53 pmIf everything is good up to the points where the red/green/white leads connect to the filters (but check that), then the problem must be within the R and C arrays and/or switches. There is no way the effect should be barely audible.
Do you know someone else who used this filters with Erwins boards?
Cheers
Gerhard
That's a good question, since some of the filter components are on the boards. Maybe Erwin can look into that? I would be happy to check for problems, but I don't have his pcb files or even a picture of the traces and component positions. Maybe they are the same as Ryan's eyelet board layout?
- Raja_Kentut
you lose always power...and heat the atmosphere the MOV only active in case of a open load condition which won't last for a long time, normally.bepone wrote: ↑Mon Mar 11, 2024 11:29 amand what about this simplicity, R=47R 5W permanently soldered to the output jack?Raja_Kentut wrote: ↑Sun Mar 10, 2024 2:44 pm a cheap way to protect the OT against secondary open condition is a MOV (metal oxyd varistor) just solder it directly over one of the output windings.
and the MOV is small...and a part that could have been used since the 30's so its "authentic"
Nothing is better than an unexpected discovery that brings you happiness!
- erwin_ve
Ill do a screenshot of the pcb, they are the same as Ryan's tho.martin manning wrote: ↑Mon Mar 11, 2024 5:35 pm That's a good question, since some of the filter components are on the boards. Maybe Erwin can look into that? I would be happy to check for problems, but I don't have his pcb files or even a picture of the traces and component positions. Maybe they are the same as Ryan's eyelet board layout?
Edit; see below
Thanks Erwin.erwin_ve wrote: ↑Mon Mar 11, 2024 6:34 pmIll do a screenshot of the pcb, they are the same as Ryan's tho.martin manning wrote: ↑Mon Mar 11, 2024 5:35 pm That's a good question, since some of the filter components are on the boards. Maybe Erwin can look into that? I would be happy to check for problems, but I don't have his pcb files or even a picture of the traces and component positions. Maybe they are the same as Ryan's eyelet board layout?
Edit; see below
I have a 1 M instead the 470k after the 1nf. And the 3nf over the 100k to ground after the 820k. I took it off the switch today for testing. The inductor is jumped. That's all.
Cheers
Gerhard
I used Erwin's boards and Martins filters and the difference between switch positions is easy to hear.Maybe I'm expecting too much. I can measure different values, but I can barely hear any difference, when I switch the positions.
Shouldn't your first cap on the switch (orange drop) be connected to the rest of the capacitor "commons" white wire? Yours is grounded.
No, it's the 3nf that is parallel to the 100k to ground at the green line.award70 wrote: ↑Mon Mar 11, 2024 7:35 pmI used Erwin's boards and Martins filters and the difference between switch positions is easy to hear.Maybe I'm expecting too much. I can measure different values, but I can barely hear any difference, when I switch the positions.
Cheers
Gerhard
Marked up layout is here: https://ampgarage.com/forum/viewtopic.p ... 79#p463579
Thanks Martin.martin manning wrote: ↑Mon Mar 11, 2024 8:26 pm Marked up layout is here: https://ampgarage.com/forum/viewtopic.p ... 79#p463579
That's exactly what I've done. Except some small value differences 1n instead 1.5n, 1m, 100k...
I think, somethings wrong with that switches and everything on it. Time to start from scratch.
I'll order the right switches from Mouser and do it again.
Cheers
Gerhard
If you are going to change the switches i can recommend using 11 position switches (blocked at 7 positions) like the original hand drawn schematic.
This way you can make a common bus for the capacitors
like the original schematic is drawn and as is visible on the gutshot of SSS001. (But if you measure the right values, i dont think new switches will make a difference.)
I don't know what else to do. The only thing thats left are the switches.
I've found it and it's a shame:
4k7 instead of 470k at the LNFB. What a bummer, so stupid
Now the filter works as expected. I think, I'll change the switches anyway. These are so bulky and hard to rotate... like an old oven...
The amp sounds totaly different now. It had a lot of sag with the 4k7. Now it sound really big and responsive. I need to explore it some more the next few days, but I'm sure I will not be disappointed at all.
Again, thank you all for your support, I really appreciate it. Special thanks to Martin for his effort with the drawings.
Cheers
Gerhard
Cheers
Gerhard
