Fender question
hebaton
Fender question
Post by hebaton »
Does anyone know ehn Fender started putting all the pots on PCBs ?
I may be interested in a 1990 DEluxe reverb RI but its in another town and the guy doesn'T want to open it.
Would this have the pot mounted to the chassis on on a PCB ?
Re: Fender question
I'm pretty sure the pots are on a separate pcb.
hebaton
Re: Fender question
Post by hebaton »
THanks, I know thats the casewitht more recent ones but I was wondering about the 1990 version witch is labeled " Deluxe reverb Amp" not 65 Reverb
HOw far back do I need to go to find one that has the pots on the chassis ?
Re: Fender question
All that has to be done is to remove a knob from the amp in question and compare.
This is front pot board and a chassis mounted pot for comparison.
Re: Fender question
I asked Bing Copilot, "When did Fender release the first 65 Deluxe Reverb reissue?"
Copilot replied, "Fender introduced the '65 Deluxe Reverb reissue in 1993."
The manual I posted was dated 1993.
hebaton
Re: Fender question
Post by hebaton »
THe amp I am looking at is a 1990 !
THe label inside ( tube complement ) says : Deluxe Reverb-Amp AB763
Re: Fender question
hebaton wrote: Tue Apr 30, 2024 9:59 pm THe amp I am looking at is a 1990 !
Show us what you are looking at. The AB763 Deluxe Reverb was only produced between 1963 and 1967!
https://ampwares.com/amplifiers/fender- ... xe-reverb/
hebaton
Re: Fender question
Post by hebaton »
Here is a picture of the Label inside the amp
Re: Fender question
Why do you say it is a 1990? Fender was not making any Deluxe Reverbs at that time and the Reissue did not go into production until 1993.
hebaton
Re: Fender question
Post by hebaton »
O.K, that.S exactly how it looks form the pics I cab see. THe seller is posting it as a 1990, but according to your info, thaat is not correct .
Think I'll pass.
Thank you !!!!!
Re: Fender question
As I recall, Fender were making valve amps with pcb mounted pots from the early 80s.
