Express Build Guide
Ron Worley
Express Build Guide
Post by Ron Worley » Mon May 05, 2008 12:14 am
After a TON of work, I have finally finished my Build Guide for your reading pleasure.
Please feel free to make any corrections, comments etc. either here or directly to me at flapsjr@hotmail.com
Numbered version now posted V1.0
Enjoy!!
Ron
RB
Re: Express Build Guide
Post by RB » Mon May 05, 2008 12:48 am
I don’t feel that I am qualified to make any technical corrections or comments, but I do want to tell you how blown away I am by this body of work and your generosity. Thank you so much.
Randy
Abstract
Post by Abstract » Mon May 05, 2008 2:37 am
May I be the first to say...
STICKY!!!
...and yes, thank you.
drhulsey
Post by drhulsey » Mon May 05, 2008 2:43 am
Ron Worley wrote:... I have finally finished my Build Guide for your reading pleasure...
Ron,
I am starting to read it tonight :D Thanks so much for sharing this resource :!:
Tim
In case the NSA is listening, KMA!
Dr-Joned
Post by Dr-Joned » Mon May 05, 2008 2:44 am
Wow !!!!! Awesome!
If you work as hard at your day job, then I want to hire you!
I did see one little item that was left off the list. Patience :lol:
I Think I Think Too Much !
Ron Worley
Post by Ron Worley » Mon May 05, 2008 2:57 am
I'm all ears, please bring on the corrections!
Ron
jjman
Post by jjman » Mon May 05, 2008 4:15 am
Great idea. Regardless of you intensions, I suggest copywriting it.
skyboltone
Post by skyboltone » Mon May 05, 2008 4:39 am
Good grief Ron:
You have really gone all out to be an positive addition to this board. Thanks very much.
Dan
Jackie Treehorn
Post by Jackie Treehorn » Mon May 05, 2008 6:30 am
Hello Ron,
Nice job. However, the picture of my amp on the top of page 52 is not the picture that illustrates the tonestack wiring. You have the "before" picture in your document. But, I would prefer not to have any of my pictures included if you're going to qualify them by saying they're "wrong."
For what it's worth in response to your comments regarding not following "proper trainwreck lead dress," when the Francesca pictures came out, I did try copying some of its' layout, particularly the wiring of the phase inverter. What I found is that it made the amp worse and I went back to the layout I had worked out based on trial and error. 8)
Best Regards,
JT
Beerman
Post by Beerman » Mon May 05, 2008 6:37 am
Can I just join the chorus and say a big THANKS for doing that and for sharing it.
__________________________________________
Cheers and Beers.
flood
Post by flood » Mon May 05, 2008 8:56 am
for an absolute noob like myself with practically no experience, this guide is mana from heaven! thanks a lot, ron - i think i speak for quite a few people here, the gargatuan effort on your part in compiling this is well appreciated. kudos!
In the interest of full disclosure, I am Animal Factory Amplification.
stevek66
Post by stevek66 » Mon May 05, 2008 10:31 am
Ron,great job ++++
Richie
Post by Richie » Mon May 05, 2008 1:13 pm
great job on the ;ist..
I was reading throught it and found a few mistakes you might want to correct..
Remember Danas Ken amp build pics, was a build in progress, it may not have every thing in the amp.
You list a 3 watt metal film for the power supply stage resistors.. those are metal oxide. If your wanting to be exact.. and 3 watt.. sometimes it depends on the resistor, what they look like in size. Some 2 watters may be as big as a 3 watter in apperence.
You have cork for the bottom plate dampening.. you could also use some felt, that you can get most anywhere..with a self sticking back.
Wiring heater section---- you have one of the wiring details after the preamp going to pin 6 of V4 and V5.. that is incorrect..
Also a couple other things in this section.. the wiring for the heaters on Fran.. alternated.. through out the chain.. like v1 4 and 5.. went to pin 9 of v2.. then pin 9 of v2 went to pin 4 and 5 of v3.. also alternated on the EL34s..
Not that you can't just wire them up the same.. and some other wrecks are not like this..but if you want to copy the exact amp..then that was how it was wired. I've seen other amps alternate like that too..
And last.. for the analists.. the resistors are placed in one certian directions..same with the signal caps..
I think i remembed also seeing the Stancor listed wrong.. Its a A-3801.. not an A-3081
Ron Worley
Post by Ron Worley » Mon May 05, 2008 1:47 pm
I have modified the document to note that I have chosen to wire my heaters "in-phase" as I was taught from my Fender days. It was intentional.
I have changed the composition on the BOMs to indicate Metal Oxide for the PS dropping resistors (and the Grid stoppers, which are the same type on my amp)
I knew that somebody would take offense somewhere. Mr. Treehorn, your picture is removed as is your name. The Reference to the post on pot lead dress remains.
The cork idea came from a post somewhere.. but I liked the ideas enough to use it.
Dana's Ken amp info was taken exactly as it is posted... just for info
Richie- sorry, what's the Stancor?? Resistor and cap orientation are wrong on my amp, it was the first thing I did, and I was not paying attention. Next amp will be right. Regardless, this guide wasn't intended to detail my level of "analness".... just how to build the amp.
Ron
Allynmey
Site Admin
Post by Allynmey » Mon May 05, 2008 2:47 pm
Hi Ron, first I would like to congratulate you on a nice looking document. As some have said here, there a few incorrect things such as name of parts and maybe procedural things but, overall I'd say that it was a nice piece of work and it will be very helpful to guys who want to build an amp. I'll try to go over it and PM you some changes. Again, nice work!
Who is online
Users browsing this forum: No registered users and 6 guests
