6AK6 push-pull output transformers
Moderators: pompeiisneaks, Structo, mhuss, HeeBGB
tube geek
Post by tube geek » Sun May 30, 2010 5:58 pm
I'm working on a 6AK6 push-pull project, and I am looking for suggestions on output transformers. I believe s2 used a Mercury, and I have found no info on the Dynotweed OT. I am also seeing 5k to 20k being used. What have you had luck with? :?:
Phil_S
Re: 6AK6 push-pull output transformers
Post by Phil_S » Sun May 30, 2010 10:02 pm
Duncan's TDSL says that Zout=10K.
FYL
Post by FYL » Sun May 30, 2010 10:18 pm
The 6AK6 is a 7-pin version of the 6G6. Same operating points etc.
mcrracer
Post by mcrracer » Mon May 31, 2010 2:03 am
MPS has a 22.5k / 4,8 and 16 ohm
and Weber has a 20k , 10k / 4 or 8 ohms
both priced right.
BT123
Post by BT123 » Tue Jun 01, 2010 2:54 pm
Hello,
1st post. I have an S2 Micro amp w/6ak. I don't think the transformer is a Mercury. I can open it up and take a few gutshots if you want.
tube geek
6AK6 push pull output transformers
Post by tube geek » Wed Jun 02, 2010 12:30 am
Thank you BT125,
A couple shots of the transformers would be nice. If you could make note of the transformer numbers that would be way cool, and much appreciated.
BT123
Post by BT123 » Wed Jun 02, 2010 2:30 am
Will do - although it might be a day or two before I have the time. I have two of them - 1 is the M1 blackface style with the 2 X 6AK6 tubes, and the other is the M3 Wreck style with 2 X EL91.
From the outside they appear to be the same transformer set.
Chappy
Post by Chappy » Wed Jun 02, 2010 4:37 pm
BT123
I am also considering building a PP with 6AK6 and another with EL91's. How do your S2 amps sound?
Chappy
Cliff Schecht
Post by Cliff Schecht » Wed Jun 02, 2010 11:21 pm
I prefer the 10kCT for 6AK6's, 20k is a bit high and sounds weaker IMO. You can always play around with impedance mismatching on the secondary side to see how different primary impedances sound.
Cliff Schecht - Circuit P.I.
BT123
Post by BT123 » Thu Jun 03, 2010 5:10 pm
Okay here are some shots. Sorry for the poor picture quality. I couldn't see any #'s on the transformers, so hopefully someone here will recognize what they are.
[img:1024:768]http://i195.photobucket.com/albums/z235 ... p005-1.jpg[/img]
[img:1024:768]http://i195.photobucket.com/albums/z235 ... Amp004.jpg[/img]
[img:1024:768]http://i195.photobucket.com/albums/z235 ... Amp003.jpg[/img]
[img:1024:768]http://i195.photobucket.com/albums/z235 ... Amp002.jpg[/img]
[img:1024:768]http://i195.photobucket.com/albums/z235 ... Amp006.jpg[/img]
BT123
Post by BT123 » Thu Jun 03, 2010 5:20 pm
I really really like these amps. The M1 is a blackface style amp that is a great pedal platform. I've heard the 6AK6 described as sounding like a small 6L6 and I think that is spot on. While it doesn't have the girth of a 6L6 for clean tones, it does sound surprisingly big and full. Blasting it with a Menatone Kar Krash or a Lovepedal Eternity at bedroom volume sounds crazy good.
The M3 is the Wreck copy. The EL91s sound like smaller EL34s. Really the same comparison as above. Fantastic saturated tone.
I really like going back and forth between the M3 cranked and the M1 with a Kar Krash pedal. They are not the same, but both crazy good and you can tell the sound is somewhat related.
It does look like both transformer sets are the same and you can see in the M1 photos that it looks like you can interchange 6AK6 and EL91 by flipping a switch.
Chappy
Post by Chappy » Thu Jun 03, 2010 8:50 pm
BT123
Thanks for the pics and the description of the amps. I can`t wait to get started on my builds. They sound like the perfect amps for me for home use only.
Cheers
Steve
tube geek
Post by tube geek » Thu Jun 03, 2010 10:46 pm
BT123,
Thanks for the photos, even though there are no numbers on the trannys the shots were cool to look at.
Thanks for the effort,
Tube Geek
Cliff Schecht
Post by Cliff Schecht » Thu Jun 03, 2010 11:30 pm
The first thing that comes to mind when looking at those trannies is Hammond. At least for the bigger one, it looks like a 272 series.
Chappy
Post by Chappy » Fri Jun 04, 2010 12:28 am
Before S2 shut down his website I took some notes to help me with my builds. All three of his small amps used Mercury Magnetics transformers. Images I have of the "Wrecktified" and the "Blackface" show black transformers without any labelling. His "Van Plexi" also used MM trannys but these were not painted black. Unfortunately I cannot make out the labels on the low quality image that I have of the Van Plexi amp.
Steve
Who is online
Users browsing this forum: No registered users and 12 guests
