Interesting reading:
http://www.vcomp.co.uk/tech_tips/reform ... m_caps.htm
I was just wondering if anyone on here has ever tried this.
Anybody ever tried "reforming" capacitors?
This message has been printed using 100% recycled electrons.
Re: Anybody ever tried "reforming" capacitors?
Here's the method my dad sent me a good while back. He does a good job of not only describing the process but what the process is specifically doing. I meant to post this a while back, I've had great results with this method.
Here’s how to reform old caps (assuming they’re salvageable):
Take the unformed or old cap and measure its capacitance value with a Fluke DVM. Be CERTAIN that you haven’t charged the cap prior to doing this. It may read fairly close to its rated capacitance value but there’s a good chance that a lot of the dielectric has deformed and the cap will leak a lot of DC current when put into service.
Reforming the cap rebuilds the dielectric layer that the manufacturer established on the cap when it was new. Once reformed, the cap will not only have its rated capacitance but it will also leak very little.
To start: Put a resistor in series with the cap you’re going to reform. Choose the value of resistance to limit the short-circuit current to no more than a couple of milliamps (watch the resistor power rating as well, in case the cap is shorted and stays that way).
Next, hook the cap up to a variable power supply (minding polarity, of course) and slowly bring the voltage up to a value that’s a bit under the rated WVDC of the cap. IF you don’t have a variable high-voltage supply, you can hook the RC setup to a non-variable HV supply and just switch the thing on, although it’s preferable to apply the forming voltage slowly. Leave the cap hooked up to the HV supply for a few minutes and then check the leakage current flowing into the cap (measuring voltage across the limiting resistor and computing the current works fine). The cap’s leakage current shouldn’t be more than a couple of milliamps…some of the older ones may leak up to perhaps 10mA.
After the cap has sat under the charging supply for a while, disconnect the HV supply and then discharge the cap through a low enough resistance to run it down fairly quickly without making a lot of sparks while doing so. Don’t dead-short it to discharge it; it makes a lot of neat sparks and noise but the high surge current is really hard on the internal structure of those older caps. Then hook the cap up to the HV supply again (through the limiting resistor), leave it for a few minutes and then check the leakage current before discharging as above. Repeating this process a few times usually reforms just about any old cap that’s still in usable shape.
After the last forming run, discharge the cap one last time through a resistance and this time, place a shorting wire across the output for several minutes. A lot of electrolytics exhibit enough dielectric absorption to allow them to recharge themselves to significantly high voltages if left unshorted after being charged and that charge can fry your capacitance meter when you go to check the capacitance one last time.
So, after the cap has sat with the short across it for several minutes, remove the short and check the capacitance with your DVM. It should read within its tolerance limits. Since it’s been reformed, it won’t leak much either.
The term “dry” electrolytic is a bit of a misnomer. Modern, polymer dielectric electrolytic are truly dry in that sense but the older aluminum-foil and paper electrolytic all had some liquid in them. They were called “dry” since they didn’t have liquid sloshing about in them. Instead, the electrolyte was typically held in a paste form. If properly stored, some pretty old caps are still usable today. It’s easy enough to check the seals to see if they’ve broken or become embrittled and a capacitance/DC leakage test will also tell you whether they’ve survived or not.
If the electrolytic caps you have were used, then it’s probably best not to try to salvage them. The heat they endured for the years they were in service in tube equipment was usually enough to compromise their integrity or even kill them. NOS parts are worth trying to reform unless they’re really old (WWII or earlier).
Cliff Schecht - Circuit P.I.
buy a sencore and press the "test" button a few times to reform. works great but keep in mind not all caps can be saved.
My Daughter Build Stone Henge
