86Special MiniHRM faceplate DXF file layout schemo and BOM
rogb
Post by rogb »
Please download and use :D
The faceplate and rear panel is for a 12x2 panel
DXF is not allowed for some reason so I have renamed it to .txt.
Download and rename to .dxf
29th March '11 - I have revised the rear panel as I forgot the OD Master on the front, no matter as there wasn't much room there, so it is on the back now along with an HRM lift switch.
Cheers
Roger
ampbldr2
Re: 86Special MiniHRM faceplate DXF file layout schemo and BOM
Post by ampbldr2 »
Can you post the schematic and layout here too?
Maybe put a sticky on this as well.
rogb
Post by rogb »
ampbldr2 wrote:Can you post the schematic and layout here too?
Sure I'll put up what I got.
I am working on a Visio layout (a la Talbany (thanks Tony)) of the final working amp as I have built it.
dreric
Post by dreric »
This is the layout for the 86 Special.
Here's the original discussion of the MT HRM AX84. There is a layout on page three or so.
Eric
rogb
Post by rogb »
See the second attachment? - it is for the original miniHRM :wink:
I think I have covered all the evolutions here, except for the 5879.
I have one of those tubes ready in case the EF86 proves to be too microphonic in the combo cab. The socket is mounted on O rings though, and I have some at the ready to damp the glass container!
