1 watt tube amp
Moderators: pompeiisneaks, Structo, mhuss, HeeBGB
9VOLT1967
1 watt tube amp
Post by 9VOLT1967 » Fri Nov 04, 2011 5:10 am
I want to build a 1 watt tube amp using a 12AU7 for a power tube and a 12AX7 for the preamp. Does anyone know of any transformers that would work for this application?
Jack Hester
Re: 1 watt tube amp
Post by Jack Hester » Fri Nov 04, 2011 5:58 am
Do you have a schematic? What kind of B+ voltages are you looking for? SS rectifier or tube?
Jack
Re: 1 watt tube amp
Post by M Fowler » Fri Nov 04, 2011 9:04 am
Here is something posted a few years ago.
rdjones
Re: 1 watt tube amp
Post by rdjones » Fri Nov 04, 2011 9:18 am
For single ended you can use a reverb driver (one with an 8 ohm secondary).
Mojo has this one for push-pull:
http://www.mojotone.com/amp-parts/trans ... -PP-Output
Cantplay
Re: 1 watt tube amp
Post by Cantplay » Fri Nov 04, 2011 11:45 am
http://acepepper.com/ThunderTweakWeb/in ... ter_v4.pdf
This looks good, although I haven't built it myself yet.
It uses a fender reverb tranny.
John
9VOLT1967
power transformer
Post by 9VOLT1967 » Fri Nov 04, 2011 12:52 pm
I am ok with the reverb transformer for the output, but I would like to use a smaller transformer other than the Hammond type. I believe I can get by with a 350V rail voltage after rectifier and 1.2 a for the heater. Maybe 15-20VA. I am working on a schematic now. Thanks for all the great info!
9VOLT1967
Voltage doubler circuit
Post by 9VOLT1967 » Fri Nov 04, 2011 2:33 pm
Here is a transformer option, but need to use voltage doubler to obtain desired voltage. Hammond 262E6 18VA 120V secondary @ 87ma. 1.2A for heaters.
Re: 1 watt tube amp
Post by xtian » Fri Nov 04, 2011 3:22 pm
I built a Firefly:
http://ampgarage.com/forum/viewtopic.php?t=11248
Very cool project, and good sounding amp.
9VOLT1967
1 watt schematic with voltage doubler
Post by 9VOLT1967 » Fri Nov 04, 2011 8:15 pm
Here is my proposed schematic for a small simple 1 watt design. My understanding of the voltage doubler is as shown. 120VAC X 2.8 = 336VDC. Is there an easier way to achieve the same results? Are the component choices ok?
renshen1957
Re: 1 watt tube amp
Post by renshen1957 » Fri Nov 04, 2011 9:11 pm
rdjones wrote:For single ended you can use a reverb driver (one with an 8 ohm secondary).
Hi,
A self-split 12A_7 design such as the Firefly was posted at the AX84 website.
I would suggest the Hammond 125 A push pull amp. Loads of options as to the primary/secondary, and I believe it runs about $33.00 from ebay.com or from Angela.
http://angela.com/hammonduniversalsingl ... rmers.aspx
Another option would be at Edcorusa.com
Their 10k primary 10Watt amp (yes, I know it is way over the 1W) is $17.22
http://www.edcorusa.com/products/354-xpp10-8-10k.aspx
Best Regards,
Steve
Cliff Schecht
Re: 1 watt tube amp
Post by Cliff Schecht » Fri Nov 04, 2011 9:54 pm
Anybody here played with using 70V line transformers as output transformers? For a 1W application there should be no problem finding a CHEAP 70V distributed line system transformer. I have a few but have never played with this myself. I know that the right ratio for a tube output stage can be achieved with one but they aren't meant to handle static DC (SE amp). But at the same time, a 10W line transformer will have no problem handling the static DC from a 1W output stage..
Cliff Schecht - Circuit P.I.
Re: 1 watt tube amp
Post by martin manning » Fri Nov 04, 2011 11:06 pm
A full wave voltage doubler looks like the attached pic. If you want 100uF total for the first filter, make each of the two caps 100uF.
9VOLT1967
Re: 1 watt tube amp
Post by 9VOLT1967 » Fri Nov 04, 2011 11:10 pm
Re-drawn voltage doubler. This will cut my amperage in half, but still should have enough power only 2 tubes- 12AX7 and 12AT7. My secondary is 120VAC. With this configuration what will my plate voltage be?
Re: 1 watt tube amp
Post by martin manning » Sat Nov 05, 2011 12:20 am
9VOLT1967 wrote:Re-drawn voltage doubler. This will cut my amperage in half, but still should have enough power only 2 tubes- 12AX7 and 12AT7. My secondary is 120VAC. With this configuration what will my plate voltage be?
Without knowing the series resistances of the PT, I'd guess about 310.
9VOLT1967
Caculation of DC voltage
Post by 9VOLT1967 » Sat Nov 05, 2011 12:41 am
What formula did you use to obtain figure?
Who is online
Users browsing this forum: No registered users and 12 guests
