The Amp Garage Forum Index The Amp Garage
A tube amp builder's community
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Gibson Historic potentiometer....
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
Post new topic   Reply to topic    The Amp Garage Forum Index -> Trainwreck Discussion
View previous topic :: View next topic
Author Message
rooster
PostPosted: Sat Jan 28, 2012 6:25 pm    Post subject: Reply with quote
Billyz, OK, noted. The funny thing here is, cleaning the trace with Deoxit in the Centralab DID wreck the feel, what there was of it - but then pulling the carbon trace and installing a new CTS shaft (brass) and top cap everything was very smooth. I can't explain this except to speculate that it was not - based on this - the Deoxit on the carbon trace. So I have to assume it is the Deoxit drifting down the shaft.
But you have a point. Using the fader cleaner would avoid all of this.
I also have this liquid 'lube tube' I use on the shaft itself. It's some type of synthetic but not clear what it is. It's clear and very viscose. The brass shafts seem to take to it, the Centralab too, but the Centralab shaft is hard to get to with that c-clip.
_________________
Most people stall-out when fixing a mistake that they have made. Why?
Back to top
View user's profile Send private message
davent
PostPosted: Sun Jan 29, 2012 11:36 pm    Post subject: Reply with quote
This discussions has pretty much centered on volume pots and i'm curious as to what people are using for the tone pots, do the various higher-end pots discussed offer sonic advantages or will any old generic pot suffice in that spot?
Thanks!
dave
Back to top
redshark
PostPosted: Mon Jan 30, 2012 1:04 am    Post subject: Reply with quote
I think in the tone spot any 500k audio taper would work but why not use the same historic pots also for tone? I put four of those in my Les paul style guitar and wired it in 50's style and it works amazingly with the express amp.
Back to top
rooster
PostPosted: Mon Jan 30, 2012 1:08 am    Post subject: Reply with quote
OK, going back to the original guitar that I was wanting to test the Centralab pots in, I finally made the swap. What I had installed were two Hamer true 30% taper pots in there - and there was not anything magical about the potting. Alright, this was a very obvious improvement! I have a real variety of tones as I pot up and down, and particularily in the 'both pickups on' position. And I can hear this on my Champ even, very obvious.
So I am a bit confused about this because I have been all into the 30% taper pots and I thought they were working well with my other guitars. In fact, the guitar I mentioned a few posts ago didn't really leave me with this clear a difference as I switched from the Hamer pot to the Centralab. ?? So I am still mulling over the possiblity that certain pickups behave differently to the various tapers. ....I won't ever get a consensus here but I am thinking this way for now.
I will do one of my LPs when the Gibson pots arrive and see if change my tune.
As to the post by davent and his question, I use the '59 style tone pot wiring on my guitars pretty much - and certainly these two guitars I just swapped out, My conclusion is that the Centralab taper really really benefits the tone pot. I say this because I left a 30% taper pot in one of the two guitars and as I compared the two it was very obvious which one had more subtle control. But now that I think about it, most of the stock pots from Fender and Gibson are what I call a 10% taper pot, although considered 'audio taper'. They may be fine for the application. Afterall, I'm looking like the crazy one who got into the 30% taper pots for guitars at this point. YM - and wallet - MV!!
And speaking of this? Would someone please do a graph of the stock Gibson pot? Has this been done? Oh, wait, it this the 511K '06 pot maybe?
_________________
Back to top
billyz
PostPosted: Mon Jan 30, 2012 3:54 am    Post subject: Reply with quote
Thanks!
dave
I actually find the taper is just as important for the tone pot as well.
I could almost live with a linear volume pot but not the tone pot.
Just an observation, I would call the centralab a 10% log taper, not 30%. I have measure many old pots in both fender and gibson. I also found them to be about 10%log not 30%. My definition of that is, at 50% rotation you get 10% of the total resistance.
_________________
http://www.billyz.net/home.html
Back to top
View user's profile Send private message Visit poster's website
rooster
PostPosted: Mon Jan 30, 2012 6:57 am    Post subject: Reply with quote
<< Just an observation, I would call the centralab a 10% log taper, not 30%. I have measure many old pots in both fender and gibson. I also found them to be about 10%log not 30%. My definition of that is, at 50% rotation you get 10% of the total resistance.>>
I couldn't agree more, billyz.
My reference and interest in 30% taper pots as volume controls in guitars stems from Joel Danzig's interest in same, the taper he used in his Hamer guitars. He heard something here, as did/do many of his customers. It may well turn out that the Centralab pot taper is my new favorite, but for now I still see/hear a value in the Joel path in some guitars.
_________________
Back to top
vibratoking
PostPosted: Mon Jan 30, 2012 3:08 pm    Post subject: Reply with quote
It's all in the Excel data on page 3 of this thread. 09 R9 is a 2009 Les Paul 59 reissue, etc... I'm bummed that you are not looking at it. Razz It tells you alot if you take the time.
The definition of taper 'standardized' as the resistance ratio at 50% of the pots' rotation. Just look at the plots and you'll see what it is for each pot. 10% taper is the goal, not 30%. 30% results in a significant loss of subtle control - on the volume and tone pots IMO.
Back to top
rooster
PostPosted: Mon Jan 30, 2012 8:27 pm    Post subject: Reply with quote
Moi? Did I not thank someone for posting the graph? It is helpful explaining in graph form what is being heard, of course.
My last point is that it's still a horse race and every jockey has his way. Joel Danzig obviously didn't care for the Centralab taper - and here I can safely assume he had experienced a '59 LP or at least some other early Gibson guitar that used Centralab pots. One man's subtle is another man's 'I don't want this, I want something different'.
For that matter add a Hamer pot graph to the mix to show where it sits against the Centralab. Smile
_________________
Back to top
redshark
PostPosted: Mon Jan 30, 2012 8:43 pm    Post subject: Reply with quote
My search started for only one reason. Finding a pot that behaves like the old centralab so playing a humbucker guitar through the express is more controlable and offer better cleans as shown in Glen's videos. When I met Glen in person @ the Nashville amp show in 09 he kindly let me use his guitar cause it had those pots and my LP classic at that time had the RS superpots. Right at that moment I learned the diference why he could get better dynamics with the express amps.
That search ended with the new 2010 Gibson historic pot. Still I have to agree that this discussion of diferent pots and graphics has been really interesting.
Back to top
vibratoking
PostPosted: Mon Jan 30, 2012 10:00 pm    Post subject: Reply with quote
I would love to. Just send me the data. Smile
Everyone has their own taste for sure. How do we know Mr. Dantzig didn't care for the Centralab? There could be a host of other reasons why the Hamer pot is 30% taper. BTW, I'd be interested to see the data that shows it is 30%.
+1 Thanks for making me aware. This is what I was after and I am enjoying the result with every amp I plug into, not just the Express.[/quote]
Back to top
ToneMerc
PostPosted: Mon Jan 30, 2012 11:59 pm    Post subject: Centralab Pot Tapers 1953 Reply with quote
I ran across this a few weeks ago when trying verify some NOS pots.
TM
Back to top
geetarpicker
PostPosted: Tue Jan 31, 2012 12:53 am    Post subject: Reply with quote
Yep, my old ones have the C2 taper.
Back to top
PostPosted: Tue Jan 31, 2012 1:05 am    Post subject: Reply with quote
Nice find TM, thanks for posting!
Back to top
ToneMerc
PostPosted: Tue Jan 31, 2012 1:32 am    Post subject: Reply with quote
The C2's haven't always been 10%. I also found a 30's curve chart that has the C2 at about 26%.
TM
Back to top
ToneMerc
PostPosted: Tue Jan 31, 2012 1:34 am    Post subject: Reply with quote
Thanks, YW,
TM
Back to top
Display posts from previous:
Post new topic   Reply to topic    The Amp Garage Forum Index -> Trainwreck Discussion All times are GMT
Page 5 of 7
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You cannot download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
