The Amp Garage Forum Index The Amp Garage
A tube amp builder's community
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
New project Tremolux 6g9-b
Goto page 1, 2, 3, 4  Next
Post new topic   Reply to topic    The Amp Garage Forum Index -> Technical Discussion
View previous topic :: View next topic
Author Message
PostPosted: Fri Jan 06, 2012 5:06 am    Post subject: New project Tremolux 6g9-b Reply with quote
A year or so ago I got stuck with an original AB763 Tremolux cab, and chassis went to another guy Embarassed
Well I am having a custom 21.25 x 7 x 1.75 slant chassis made to fit my new Tremolux faceplate I just received from Tube Amp Doctor.
I'm going to use one of my Hammond organ PTs and Mojotone fender replacement OT.
I had an original grey tolex cab AB763 with brown faceplate and cream knobs that I sold to Mike Keller now I can replace that amp finally.
Back to top
View user's profile Send private message Send e-mail Visit poster's website
tubeswell
PostPosted: Fri Jan 06, 2012 5:40 am    Post subject: Reply with quote
Cool! I've always fancied building one of those.
_________________
Back to top
PostPosted: Sun Jan 15, 2012 12:56 am    Post subject: Reply with quote
Received a custom chassis today ordered off ebay from Seaside Music for the Tremolux which is 21.25 x 7 x 1.75 chassis.
I maybe could have squeezed it to 7.25 or so but the chassis fits perfectly.
The Tremolux faceplate is available from www.tubeampdoctor.com The faceplate is brown it looks black in the second picture.
Next will be marking, drill, punching and drueling. Laughing
Back to top
Cliff Schecht
PostPosted: Sun Jan 15, 2012 6:24 am    Post subject: Reply with quote
I've been thinking about building an EL84 Tremolux. I just put together a 2x12 cab with some really nice old Jensen 12" speakers. The cab sounds fantastic with a Champ but I'm afraid to throw anything more than a Deluxe at it because I'm not sure the Jensen PM12C in there can handle more than 10W or so. I figured the EL84 Tremolox would be a good compromise but 84's can kick out a lot of sound from that small envelope. I really don't want to blow this speaker!
I'll keep an eye on this thread and I look forward to seeing the results. I've built most of the tweed circuits and am just starting to dig into the brown era Fender stuff (just finished a few 6G15's and have a 6G16 started on the bench!).
_________________
Cliff Schecht - Circuit P.I.
Back to top
View user's profile Send private message Visit poster's website
PostPosted: Sun Jan 15, 2012 1:49 pm    Post subject: Reply with quote
Cliff,
Your project idea would be a very unique amp. It wasn't that long ago that I heard about this EL84 Fender amp. I think I would like the EL84's over the 6V6 tubes myself.
Back to top
PostPosted: Sun Jan 15, 2012 2:48 pm    Post subject: Reply with quote
Mark and Cliff, since you guys are delving into these brown-era amps, here's an alternative to the tapped treble pot used in the tonestack. This idea popped into my head over the holidays, and a sim shows it to be very close to the original in frequency response. There is just a bit of additional mid scoop, and it doesn't kill the high-end quite as much, but it is very close.
Back to top
PostPosted: Sun Jan 15, 2012 5:25 pm    Post subject: Reply with quote
Martin thanks for the information very appreciated.
I do have the tapped pot so will proceed that way but nice to know one can work around that.
Back to top
Cliff Schecht
PostPosted: Sun Jan 15, 2012 6:23 pm    Post subject: Reply with quote
I don't have a pot and I don't want to buy one. I'll give Martin's circuit a shot for sure. Martin do you mind my asking how you came up with the idea? I guess I can see what you are doing but tapped pots always give me a headache when it comes time to actually design them into a circuit (too many degrees of freedom). Sorta like how those crazy Switchcraft switching style jacks can profoundly confuse with how many solder lugs there are (see below). I did find a 250k pot with a 50k tap (same ratio as 350k/70k) but I don't like changing the tonestack loading unless I adjust all of the R's and C's accordingly.
Thumbnail, click to enlarge.
_________________
Back to top
PostPosted: Sun Jan 15, 2012 6:46 pm    Post subject: Reply with quote
Cliff, it was like this: Hmmm... need a 350k pot. OK, put a shunt across a 500k pot. Need a 350k tapped pot... OK, put the tap on the shunt! The real test would be to A-B it with a tapped pot, but I'm betting it will get the job done in good style. A 1M is close enough if you lack a 1.1, the response changes very little. Turned out to be very simple to implement, too.
Back to top
PostPosted: Sun Jan 15, 2012 6:47 pm    Post subject: Reply with quote
Doesn't Weber sell those 350K tapped pots?
_________________
Back to top
PostPosted: Sun Jan 15, 2012 6:50 pm    Post subject: Reply with quote
They do, but they are 16mm. This way you can have a matching set of whatever your favorite brand is.
Back to top
dayn
PostPosted: Sun Jan 15, 2012 7:36 pm    Post subject: el-84 tremolux Reply with quote
One on eBay right now:
http://www.ebay.com/itm/STUPID-RARE-Vintage-1961-Pre-CBS-Fender-TREMOLUX-EL84-Guitar-Amplifier-RAAAARE-/360426504615?pt=LH_DefaultDomain_0&hash=item53eb1801a7
Back to top
PostPosted: Sun Jan 15, 2012 9:45 pm    Post subject: Reply with quote
Some good photos with that ebay listing.
Back to top
tubeswell
PostPosted: Mon Jan 16, 2012 2:01 am    Post subject: Re: el-84 tremolux Reply with quote
Yee-ikes. $15k! Shocked I'm sure its worth every penny. Confused
_________________
Back to top
PostPosted: Mon Jan 16, 2012 3:48 am    Post subject: Reply with quote
Cliff the Fender PA100 I am working on right now has those jacks on the speaker out. Beefy suckers.
Back to top
Display posts from previous:
Post new topic   Reply to topic    The Amp Garage Forum Index -> Technical Discussion All times are GMT
Page 1 of 4
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You cannot download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
