Circuit: High plate Skyliner, #102 values
PT: custom Heyboer MusicMan style PT
OT: custom high plate voltage compatible Heyboer Twin style OT
Signal path : vintage 6PS orange drops, Piher CF, 30% taper pots
Tubes: quad JJ 6CA7, da fat ones
TM
Thanks, yes both aree 100K and yes keeping the Dale 65'sdcribbs1412 wrote:Looks great TM...
you are inspiring with your builds lately.
are both OD pots 100K?
you keeping the Dale's on V1 and 2?
thanks for sharing
Darin
Tony, as a placeholder there's 40K/707K right now. The expectation was to drop in the 820K bleeder with the 40K, so I will try that first. The last config I only used a 5H choke on the screens, never thought of using a choke on the PA as well. Hmmm, I do have a Deluxe choke in the parts bin. I went +.625 thicker on the lam stack, which placed the OT slightly closer to the choke, but I should have room to pinch in the smaller choke if I do so,talbany wrote:Mike
The dropper for the PI should be around 43k 10w/w 750k bleeder on the plate side.. If you have room and an extra choke laying around choke the screens and pre amp..good Luck..The Fat boy 6CA's are big sounding..You will like them..Due to the higher voltage on the plates you might not need to filter it as much..I've seen both 50uf and 100uf..Choose your poison..![]()
In both cases I've had a Twin style OT specifically wound for this setup.Roe wrote:Does the MM PT and the twin OT work together? won't you have too high plate voltage for a 2k load?
awesome as usual Mike, i can def VOUCH for Qlines, OMG what a beautiful sound! I used just ONE in a critical junction, and it bLEW my mind, man, i miss my some of my older marshalls! Hopefully BAL wil come thru soon!ToneMerc wrote:I fused, powered it up minus the HT windings to check all the low voltage circuits and they all are a go.
AC = 124.8V, PT PRI = 120V
Unloaded filament voltage @ V1 = 6.85V
Unloaded max bias @ 270K junction = -40.0V, hopefully under load I can get it around -22 or so on the grids.
Relay supply = 5.99V
TM
groovtubin wrote:awesome as usual Mike, i can def VOUCH for Qlines, OMG what a beautiful sound! I used just ONE in a critical junction, and it bLEW my mind, man, i miss my some of my older marshalls! Hopefully BAL wil come thru soon!ToneMerc wrote:I fused, powered it up minus the HT windings to check all the low voltage circuits and they all are a go.
TM![]()
clips PLS!
Omegaamp jim
Thanks Shadampdork wrote:That's the stuff right there.
