New EL34 rocket...
tubedogsmith
New EL34 rocket...
Post by tubedogsmith »
Here's a 4 EL34 Rocket style amp I just finished with a speaker cab. I had some transformers wound just for this and it all came out great. It is really nice sounding. Lot of fun to play.
Bob S
Re: New EL34 rocket...
Post by Bob S »
Wow - that's a thing of beauty!
Love the figured maple - my favorite.
How does she sound ?
Stunning looks.
Why Aye Man
tubedogsmith
It's very smooth and tight sounding. Lots of thump. Between working the master and the half power switch you can get a whole range of the same type sounds at vastly different volume levels. It came out with a lot more going on than I anticipated.
Bear
Post by Bear »
Cathode bias, no NFB setup?
Koop
Post by Koop »
Very nice. Congratulations.
johnnyreece
Post by johnnyreece »
Sharp! 8) Love curly maple.
Roe
Post by Roe »
basically like an ac100. I have a drake type OT (1202-132) lying around and am tempted to build one myself
Colossal
Post by Colossal »
Really a great looking build, all around! Great looking layout. Love the cabinets too (wow).
What PT did you settle on? I think I see the bias set to 150R/220uF(?) per pair? Did you try to mimic the 120% bias condition for the AC30? or something a little more conservative.
tubedogsmith
Thanks. It's not biased real hot and plate voltage is just 370Vdc. 6L6's sound real nice in it as well.
Yes, it's cathode bias, no nfb.
Colossal
Post by Colossal »
tubedogsmith wrote:Thanks. It's not biased real hot and plate voltage is just 370Vdc. 6L6's sound real nice in it as well.
So about 17W per tube. Sweet. So is your PT running about 300 or 310VAC through two GZ34s?
Reeltarded
Post by Reeltarded »
Blondie! Nice looking rig!
Bob S
Post by Bob S »
And blondes are more fun...
So are brunettes, redheads and (amps) with black hair.
The worst one you ever played with was pretty good right?
Otherwise it's you're instrument or technique....
:lol:
Why Aye Man
Nice amp :)
I enjoy my four EL34 Rocket with reverb a lot as well nice sounding amp.
Roe
Post by Roe »
I want to build one like that myself. I have a 1k7 OT and need a 100w PT. Triode has a plexi PT for around 70usd that should work for an ac100. Do you feel the chassis works well for a 4xel34 amp or do you recommend something bigger? I'd prefer keeping the PT and OT apart to avoid hum
tubedogsmith
The power tranny is a TW style that is beefed up for extra current handling. The OT is based on an article I read by Dave Funk years ago. I'm not a transformer guy so I'm not going to parrot this stuff but it's a twin style frame built to handle a 100% duty cycle with balanced windings. The rig is dead quiet at idle, quiet as in you can't tell it's on quiet.
There is plenty of build room in this chassis but the output tubes could use more space for sure. Transformer orientation is not an issue though.
