New Ceriatone OTS 50 Build
eazilyled
Post by eazilyled »
Here's my completed build.
It's a 50w OTS I built from a kit.
For transformers, I used Hammond bassman type replacements (PT 291DEX, OT 1760L, Choke 194B).
My voltages were a touch high initially (477V at power tube plates, ~200V at V1 plates), so I increased the 3K3 dropper resistor to 4k7.
This got the preamp plate voltages down a touch, so I ended up with ~190V at V1 plates.
I also adjusted the PI trimmer for a 6V difference at the V3 plates.
For tubes, I used some old Mullard ECC83s in V1 / V2, a new Tungsol in V3 and TAD 6L6s in V4 / V5.
Other than an intermittent standby switch which I suspect I caused through overheating, the build was pretty straight forward and luckily it fired up first time.
I didn't build the head cab, I got that from Tube Town.
I'll probably invest in a G1265 loaded cab and some sort of Dumbleator eventually.
I'm quite pleased with the sound of the amp. I have to say it's a bit of a strange novelty to be able to use the master volume to keep the sound levels down - I've been used to having to use an attenuator with my Express build :D
hywelg
Re: New Ceriatone OTS 50 Build
Post by hywelg »
Nice..
Is that all stock Ceriatone parts except for the trannies?
eazilyled
Post by eazilyled »
Thanks. Yes all stock parts apart from the trannies which required new mounting holes, and the intermittent standby switch (used same Carling type). Come to think of it, I also swapped out the voltage regulator because I goosed it up when soldering.
I think I recognise your user ID from the Ceriatone forum?
The build looks good, now to get some play time on that amp, right :!: :)
eazilyled
Post by eazilyled »
M Fowler wrote:The build looks good, now to get some play time on that amp, right :!: :)
Thanks Mark! Yes, playing is going to be a priority for me now, both for the purposes of break-in and pleasure :D
These D style amps are kind of epic in terms of build effort, so it's a nice reward to be finally able to play it.
hywelg
Post by hywelg »
eazilyled wrote: Thanks Mark! Yes, playing is going to be a priority for me now, both for the purposes of break-in and pleasure :D
Yes, I did spend quite a lot of time over at the Ceriatone forum, gone dead there now, hang out here a lot more, much more knowledgeable folks :D
My OTS did take quite a while to break in properly. I still found the OD a bit harsh when I have the clean EQ'd as I like it and that prompted me to fit a cut control to the OD. Works a treat.
eazilyled
Post by eazilyled »
Sounds good hywelg. I keep reading about doing the 'bright switch on clean only' mod which I believe achieves a similar effect as your mod.
No I believe he is talking about a simple tone control on the OD channel.
Some call it a treble bleed circuit.
It is a cap and trimmer to dial down the treble response of the OD.
The "Bright on Clean" switch mod adds another relay that turns on a bright cap when in clean mode.
I really like this mod.
Shown below.
eazilyled
Post by eazilyled »
Thanks Tom I may do one of those eventually. I'll see how it goes in a band situation first
hywelg
Post by hywelg »
Structo wrote: It is a cap and trimmer to dial down the treble response of the OD.
No its this one, caps only to bleed treble off
http://ampgarage.com/forum/viewtopic.ph ... 236#233236
