ODRS #13 Layout & Schematic
Thought I would have a go at tidying up the blurry hand drawn layout that is supposed to be ODRS #13, dated 8th August 76.
Circuit is not 100% confirmed. Some values that I couldn't make out I took from the 2nd Gen files.
I have not built or tested so assume it has errors.
If anybody knows or has seen this amp I would appreciate any input. Feel free to send me anyhting
Thanks,
Aaron
Thanks,
Aaron
Re: ODRS #13 Layout & Schematic
There are the photos of #60 and Normster's ODR but not sure how much different they are from #13.
Well crafted; thanks for your work!
- David Root
Thanx for your work! Much easier on the eyes than the drawing that's for sure!
Can someone shed some light on what is happening between The reverb return(V2A) and The mixer(V4A) in regards to the .1uf cap in series with 100K and 100R cathode resistor lift?
well, let's call Howard!txbluesboy wrote:I realize thats it's a LNFB loop, but why here?
(to add smoothness, a bit of compression, etc.)
Chris
Love, peace & loudness!
Am I crazy, or is the reverb BEFORE the OD? Is that intentional? It seems that it would have the same problem I am having in my own Traynor YGL3 HRM, where anything but minimal reverb gets out of control once the OD is switched on...
Is there any documentation of reverb after an OD circuit?
Last edited by amplifiednation on Mon Feb 15, 2016 8:49 pm, edited 1 time in total.
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
Last edited by amplifiednation on Mon Feb 15, 2016 8:50 pm, edited 1 time in total.
Amplified Nation
@ampnation
@ampnation
- ElectronAvalanche
Here are some pics I took of an ODSR some time ago. Hope this helps!
Electron
Electron
I'm so happy right now I could cryElectronAvalanche wrote:Here are some pics I took of an ODSR some time ago. Hope this helps!
Electron
Thank you so much for these.
Aaron
"F" connects to the mixer valve. That's what I could guess from the blurry hand drawn.amplifiednation wrote:I don't get the node F on the power supply and what it's connecting to? The plates should be getting 400v from the reverb transformer, is there more voltage being fed in from that node to the plates of v3?
Aaron
