| View previous topic :: View next topic |
| Author |
Message |
Ron Worley
Posted: Mon May 05, 2008 12:14 am Post subject: Express Build Guide |
After a TON of work, I have finally finished my Build Guide for your reading pleasure.
Please feel free to make any corrections, comments etc. either here or directly to me at flapsjr@hotmail.com
Numbered version now posted V1.0
Enjoy!!
Ron
| Back to top |
RB
Posted: Mon May 05, 2008 12:48 am Post subject: |
I don’t feel that I am qualified to make any technical corrections or comments, but I do want to tell you how blown away I am by this body of work and your generosity. Thank you so much.
Randy |
| Back to top |
Abstract
Posted: Mon May 05, 2008 2:37 am Post subject: |
May I be the first to say...
STICKY!!!
...and yes, thank you. |
| Back to top |
drhulsey
Posted: Mon May 05, 2008 2:43 am Post subject: Re: Express Build Guide |
| Ron Worley wrote: | | ... I have finally finished my Build Guide for your reading pleasure... |
Ron,
I am starting to read it tonight Thanks so much for sharing this resource  _________________ Tim
Budgets and statistics (i.e., the government) have no conscience. |
| Back to top |
Dr-Joned
Posted: Mon May 05, 2008 2:44 am Post subject: |
Wow !!!!! Awesome!
If you work as hard at your day job, then I want to hire you!
I did see one little item that was left off the list. Patience  _________________ I Think I Think Too Much ! |
| Back to top |
Ron Worley
Posted: Mon May 05, 2008 2:57 am Post subject: |
I'm all ears, please bring on the corrections!
Ron |
| Back to top |
jjman
Joined: 06 Oct 2007 Posts: 386 Location: Central NJ USA
Posted: Mon May 05, 2008 4:15 am Post subject: |
Great idea. Regardless of you intensions, I suggest copywriting it. _________________ If it says "Vintage" on it, -it isn't. |
| Back to top |
skyboltone
Joined: 10 May 2006 Posts: 1832 Location: Sparks, NV, where nowhere looks like home.
Posted: Mon May 05, 2008 4:39 am Post subject: |
Good grief Ron:
You have really gone all out to be an positive addition to this board. Thanks very much.
Dan _________________ The Last of the World's Great Human Beings
Well, maybe next to the last, or one of the last?
Ok a perfectly ordinary slacker......
Seek immediate medical attention if you suddenly go either deaf or blind. |
| Back to top |
Jackie Treehorn
Joined: 20 Jan 2005 Posts: 129 Location: Northern California
Posted: Mon May 05, 2008 6:30 am Post subject: |
Hello Ron,
Nice job. However, the picture of my amp on the top of page 52 is not the picture that illustrates the tonestack wiring. You have the "before" picture in your document. But, I would prefer not to have any of my pictures included if you're going to qualify them by saying they're "wrong."
For what it's worth in response to your comments regarding not following "proper trainwreck lead dress," when the Francesca pictures came out, I did try copying some of its' layout, particularly the wiring of the phase inverter. What I found is that it made the amp worse and I went back to the layout I had worked out based on trial and error.
Best Regards,
JT |
| Back to top |
Beerman
Joined: 01 Mar 2007 Posts: 52 Location: Melbourne, Australia
Posted: Mon May 05, 2008 6:37 am Post subject: |
Can I just join the chorus and say a big THANKS for doing that and for sharing it. _________________ __________________________________________
Cheers and Beers. |
| Back to top |
flood
Joined: 30 Jan 2008 Posts: 193 Location: Bombay, India
Posted: Mon May 05, 2008 8:56 am Post subject: |
for an absolute noob like myself with practically no experience, this guide is mana from heaven! thanks a lot, ron - i think i speak for quite a few people here, the gargatuan effort on your part in compiling this is well appreciated. kudos! _________________ "Political correctness does not legislate tolerance; it only organizes hatred." - Jacques Barzun |
| Back to top |
stevek66
Posted: Mon May 05, 2008 10:31 am Post subject: |
| Ron,great job ++++ |
| Back to top |
Richie
Posted: Mon May 05, 2008 1:13 pm Post subject: |
great job on the ;ist..
I was reading throught it and found a few mistakes you might want to correct..
Remember Danas Ken amp build pics, was a build in progress, it may not have every thing in the amp.
You list a 3 watt metal film for the power supply stage resistors.. those are metal oxide. If your wanting to be exact.. and 3 watt.. sometimes it depends on the resistor, what they look like in size. Some 2 watters may be as big as a 3 watter in apperence.
You have cork for the bottom plate dampening.. you could also use some felt, that you can get most anywhere..with a self sticking back.
Wiring heater section---- you have one of the wiring details after the preamp going to pin 6 of V4 and V5.. that is incorrect..
Also a couple other things in this section.. the wiring for the heaters on Fran.. alternated.. through out the chain.. like v1 4 and 5.. went to pin 9 of v2.. then pin 9 of v2 went to pin 4 and 5 of v3.. also alternated on the EL34s..
Not that you can't just wire them up the same.. and some other wrecks are not like this..but if you want to copy the exact amp..then that was how it was wired. I've seen other amps alternate like that too..
And last.. for the analists.. the resistors are placed in one certian directions..same with the signal caps..
I think i remembed also seeing the Stancor listed wrong.. Its a A-3801.. not an A-3081 |
| Back to top |
Ron Worley
Posted: Mon May 05, 2008 1:47 pm Post subject: |
I have modified the document to note that I have chosen to wire my heaters "in-phase" as I was taught from my Fender days. It was intentional.
I have changed the composition on the BOMs to indicate Metal Oxide for the PS dropping resistors (and the Grid stoppers, which are the same type on my amp)
I knew that somebody would take offense somewhere. Mr. Treehorn, your picture is removed as is your name. The Reference to the post on pot lead dress remains.
The cork idea came from a post somewhere.. but I liked the ideas enough to use it.
Dana's Ken amp info was taken exactly as it is posted... just for info
Richie- sorry, what's the Stancor?? Resistor and cap orientation are wrong on my amp, it was the first thing I did, and I was not paying attention. Next amp will be right. Regardless, this guide wasn't intended to detail my level of "analness".... just how to build the amp.
Ron |
| Back to top |
Allynmey Site Admin
Joined: 06 Mar 2005 Posts: 1253 Location: Dighton, MA
Posted: Mon May 05, 2008 2:47 pm Post subject: |
Hi Ron, first I would like to congratulate you on a nice looking document. As some have said here, there a few incorrect things such as name of parts and maybe procedural things but, overall I'd say that it was a nice piece of work and it will be very helpful to guys who want to build an amp. I'll try to go over it and PM you some changes. Again, nice work! _________________ www.ampbuildersparts.com |
| Back to top |
