100k Plates and F style stack non-hrm clip
Amp has 100k plates on V1, 220k/150k on V2 Preamp and master both at noon, Bass and Treble both at noon. OD trimmer at 50% OD drive at 2'oclock Level at 7:30 and mid boost on. This amp has a Blackface Princeton stack (no mid knob and a .047 connected to the 10k on the bass pot) The only effect is the 2 tube reverb built in the amp. Single 12" TonkerLite. Player is Tim Betts (cousin of Dicky) who normally plays with C.J.Chenier but sat in on this gig with some local Phoenix guys. The guitar is a Zion with active. I cut and pasted a few solos together, all of which are at the exact same amp settings. Recording quality is not great, it was done on a still camera in movie mode.
http://myspacetv.com/index.cfm?fuseacti ... d=34850007
www.RedPlateAmps.com
Re: 100k Plates and F style stack non-hrm clip
Man, that's great tone, you got there AND a great player
Delicious bluesy tone.Great playing too.
I love the sound and playing Would be nice to hear the amp recorded with a pair of good microphones.
Thanks for shearing !
mat
So it's in OD, right?
Yeah OD always on - he's one of those guys that won't use a footswitch and does everything from the guitar, never touching the amp all night unless more volume is needed.jaysg wrote:So it's in OD, right?
- Luthierwnc
What is the power section in that amp? Skip
Not sure what you're asking - it has a Bassman PT and a prosonic OT, B+1 is 465V(486 on standby) and dropping string is 390R,3k3,27k,2k2 with 150k to ground. The reverb shares the PI node (B+3). This is a dual 6L6 cathode biased amp using 500 ohm (drops 41 volts for both tubes) with 100uf bypass.Luthierwnc wrote:What is the power section in that amp? Skip
No flies on that tone!! Great!
- Luthierwnc
Thanks Heisthl, that was exactly what I wanted to know. Good playing and tone! It looked like a good room, too.
Cheers, Skip
Cheers, Skip
Besides the 220k/150k on V2 Preamp, what kind of component values are you using on v2.heisthl wrote:Amp has 100k plates on V1, 220k/150k on V2 Preamp and master both at noon, Bass and Treble both at noon. OD trimmer at 50% OD drive at 2'oclock Level at 7:30 and mid boost on. This amp has a Blackface Princeton stack (no mid knob and a .047 connected to the 10k on the bass pot) The only effect is the 2 tube reverb built in the amp. Single 12" TonkerLite. Player is Tim Betts (cousin of Dicky) who normally plays with C.J.Chenier but sat in on this gig with some local Phoenix guys. The guitar is a Zion with active. I cut and pasted a few solos together, all of which are at the exact same amp settings. Recording quality is not great, it was done on a still camera in movie mode.
Could it be:
200k input
100k trim
68k input v2a
220k anode /3,3k/5uf cathode
10n anode out
100k
level pot 100k
180k input v2b
150k anode /2,2k /5 uFn cathode
5nF
180k
100k ratio pot
I really would appreciate your reply my ceraitone OD is drivin me crazy and and do love that tone on your clip
Could it be:
200k input
100k trim
68k input v2a
10n anode out
100k
level pot 100k
180k input v2b
5nF
180k
100k ratio pot
Almost - the entrance is 220k and when I use a 100k ratio I feed it with 150K.
For a while I had my #124 clone set up with 100k on both sides of V1 and the 220/150k on V2 with values similar to what you posted. It sounded very good like that.bluesfendermanblues wrote:
