5E3 and 5F6A PCB gerber files
Design and discussion around PCB Design that doens't suck!
Lauri
Post by Lauri »
For my COVID isolation projects I built a tweed deluxe and a bassman combo. Here are the gerber files for the PCB's incase anyone is interested.
5E3:
http://ghr.fi/amps/5e3/5e3pcb-220mmx-70mm.zip
http://ghr.fi/amps/5e3/5e3.pdf
5F6A
http://ghr.fi/amps/5f6a/5f6apcb-290mmx70mm.zip
http://ghr.fi/amps/5f6a/5f6a.pdf
Re: 5E3 and 5F6A PCB gerber files
Nice!
chief mushroom cloud
Post by chief mushroom cloud »
Yea, well done!
Don't overthink it. Just drink it.
erwin_ve
Post by erwin_ve »
That does look really nice! Thanks for sharing! 1 question: does the ground plane under/close to high impedance paths/components have a impact on the tone?
tristanc
Post by tristanc »
Great stuff
Lauri
Post by Lauri »
erwin_ve wrote: Tue May 12, 2020 7:58 am does the ground plane under/close to high impedance paths/components have a impact on the tone?
12AX7 tubes have such a high miller capacitance and guitar amps in general have a very limited frequency response. I doubt the small capacitances and inductances between traces, ground planes and components on the PCB will make any difference.
norburybrook
Post by norburybrook »
Lovely.
When you have these files I presume you send it to somewhere that can make the boards. Will places make just one board or do yo have to get say 10 made, and are they expensive?
p.s Lauri, just been watching the new series of bordertown on Netflix :D kippis :D
M
Lauri
Post by Lauri »
I usually use https://jlcpcb.com/ to order PCB boards. Minimum quantity is 5. When I ordered PCB's for both of the amps the total cost was about 45€ including shipping and taxes.
wallybob
Post by wallybob »
What software are you using, if i might ask?
Lauri
Post by Lauri »
wallybob wrote: Wed Oct 21, 2020 10:40 pm What software are you using, if i might ask?
KiCad
https://kicad-pcb.org/
wallybob
Post by wallybob »
How about posting KiCad files?
jwhousley
Post by jwhousley »
wallybob wrote: Sat Oct 24, 2020 8:56 pm How about posting KiCad files?
YES!!! That will help with learning the kicad software!!
Lauri
Post by Lauri »
Bassman and Deluxe KiCad files
wallybob
Post by wallybob »
Thanks for posting that Lauri. I took your schematic file and modified it for a Tweedle Dee Deluxe. Now I'm looking at assigning footprints for components and it looks like all of your components come from some Uraltone library - is this your company? Are none of these components similar to standard library components?
Lauri
Post by Lauri »
Uraltone is a company I've done some PCB design work for. You can find all the libraries and footprints used on that PCB in the libs_and_footprints folder. They're very similar to components found in the standard library. Pretty much the only difference in the footprints I've made is that pads and holes are much larger so it's easier to desolder components and do mods.
