70's and 80's Dumbles........
norburybrook
Re: 70's and 80's Dumbles........
Post by norburybrook »
teleman1 wrote: Tue May 18, 2021 4:12 pm Thanks , very much , Jim
Jim,
Last thing...these amps need to be pretty loud IMHO to open up so bear that in mind :) and thanks for the kind words.
M
teleman1
Post by teleman1 »
Ah i dont play two loud i have the dumbleator low , but not loud to me is loud to my sound man !! My amp is like a 80’s low plate in a fender Bassman chassis , but this seems cool, take care
talbany
Post by talbany »
teleman1 wrote: Tue May 18, 2021 3:35 pm Cool, do you have the exact lay out of that dumble ,? I liked how with all that gain which i dont use that much gain but when the treble tone pot was opened up it still had that tele bite , i wish there were more audio clips of that dumble with a tele !! Take care and thanks for getting back , Jim Weider
Hello Jim
Since I did the layouts on both 2nd and 3rd generation amps i'll respond. The 2nd Generation layout was not taken from any one specific amplifier but a combination of many from that era from a person who had been in and worked on many of these amps, so this was the common theme that ran through all of them (Design and components)
I tend to think of the 3rd generation as being an upgraded version of a 2nd generation. These were alterations done mainly with the tone stack and RGU-59 coax. Both 2nd and 3rd generation amps share similar sonic personalities!.It wasn't until the later transition 4th generation amps that were later radically modified. Both 2nd and 3rd generation are wonderful amplifiers :D
Max posted the layout of the 3rd generation being closest to Karl's O.D.S
3rd generation made around the 1978-1979 Ser# around 60-75..
Since these alterations occurred around a 2 year time frame and more than 1 or 2 amps and for the sake of accuracy should be referenced as 3rd generation ODS and shouldn't be looked upon as tweaks or custom voicing s for a certain customer..
Changes are listed on the top right of the layout are
https://ampgarage.com/forum/viewtopic.p ... 61#p140261
1 Treble: 250KA treble pot
2..005 soldered between the wiper and top of the Bass pot
3.Black RG59/U 75 ohm foam - similar looking as the Tandy Wire RG59/U 75 ohm foam in ODS #094,(see below picture) but without the "Tandy Wire" label
Although this layout wasn't taken from an actual 3rd generation specimen perhaps I'll run across one here in the future..If so I'll make another separate layout better reflect the accuracy's of that amp (3rd Generation)
3rd generation "pre-classic" clips: (Posted By Max)
http://ampgarage.com/forum/viewtopic.ph ... 117#135117
http://ampgarage.com/forum/viewtopic.ph ... 120#135120
http://ampgarage.com/forum/viewtopic.ph ... 121#135121
Clean sound of a 3rd generation "pre-classic" Overdrive Special 50W combo with 12" Altec 417-8H Series II with a paper dust cap mod
Karl Ratzer "I Fall In Love Too Easily"
Karl Ratzer – guitar
Karl Hodina - accordion
Don't miss Karl Hodina playing his accordion!
More discussion
http://ampgarage.com/forum/viewtopic.ph ... 428#138428
Max
Post by Max »
Unfortunately none of the links in talbany's previous post work anymore.
Here is the link to all recordings for the album "Moondancer", for which Karl Ratzer used his 3rd generation ODS50W combo:
https://www.youtube.com/watch?v=MXWja1Q ... kRG9je72fg
These recordings are also a good example of how this amp sounds at studio volume.
teleman1
Post by teleman1 »
Thanks very much ,
Dr d
Post by Dr d »
Max wrote: Fri Mar 19, 2021 1:28 pm
teleman1 wrote: Sun Mar 14, 2021 8:44 pmLove that example of the tele max did in the 70’s style amp. Love to talk about that amp and what was used?
AFAIR he used his Fender Nocaster for this track and his 3rd generation ODS 50WX Combo (hardwood cabinet similar to the late 70ies early eighties Boogie hardwood cabinets). AFAIR the speaker in this cabinet at the time of this recording was an Altec 417-8H SERIES II. The original metal dust cap had been replaced by a paper dust cap. You can get some glimpses of this combo on this video (No Nocaster :D). "Village Feeling" starting around 18:00. Have fun!
Cheers,
Max
Hey Max," "Village Feeling" starting around 18 " is perhaps the best example I have heard of the 3rd gen amp. I wish I had heard this before now, and this has inspired me to listen to more of his material. Thank you for sharing this :).
ijedouglas
Post by ijedouglas »
Dr d wrote: Mon Apr 22, 2024 11:19 am Hey Max," "Village Feeling" starting around 18 " is perhaps the best example I have heard of the 3rd gen amp. I wish I had heard this before now, and this has inspired me to listen to more of his material. Thank you for sharing this :).
Great tone! I think I had that song on repeat for about a month while I was building my 3rd Gen :D
Ian
Dr d
Post by Dr d »
ijedouglas wrote: Wed May 15, 2024 1:42 pm
It's a great reference for sure!
