Steel String Singer #001/#002/#004 Layout/Schematics
Re: Steel String Singer Layouts/Schematics
Here’s layout I did for SSS #001 and SSS #002.
I haven’t built from the layouts but I think Sergio did a #002 build.
Aaron
https://ampgarage.com/forum/viewtopic.p ... &start=135
https://ampgarage.com/forum/viewtopic.p ... 001+layout
Aaron
Re: Steel String Singer #002 Layout/Schematics
I’m out on tour at the moment but also have layouts for #004 and #005 back at home.
Aaron
Aaron
Re: Steel String Singer #001/#002 Layout/Schematics
Okay so I've just decided to update the first post, and link to all these layouts being shown. I don't think I'll need to create one for 002 since it looks like we've got one. Thanks Aaron!
Keep the submissions coming of layouts or schematics and pics of the real deal or clones and we can update the thread.
Re: Steel String Singer #001/#002/#004 Layout/Schematics
I am starting to make SSS #002 board layouts here using DIYLayout Creator. https://github.com/colganr/steel-string ... er/Circuit Once the boards are completed, I'll make the overall drawing to share with everyone. Feel free to download/modify/re-upload and I'll combine the changes back in the "master" repository above. I'm mostly using Aaron's layout for the inspiration and cross referenced with the hand-drawn and .sch #7 revision schematics. I'm going back and forth about the power supply approach for this one. I might just do the offboard Twin Reverb rectifier/bias instead of including it on the PS board to avoid noise from the rectifiers bleeding in. I'm waiting on parts to come in so I can verify my layout size to accommodate F&T caps.
The SSS #002 chassis I had fabricated are already set so if you modify the board layouts, please leave the 9pins in the exact position so they line up to the chassis holes. This is exciting stuff!
Ryan
https://www.thetonegeek.com/
I am throwing my hat in the ring for a SSS #002 layout with some minor corrections/tweaks based on the available documentation (hand drawn schematic, rev 7.sch file, SSS #004 via Two Rock Sterling Sig) as well as Sergio's build. Layout heavily inspired by Aaron's layout.
NOTES
Layout made with DIYLC and my latest changes can be downloaded here (Right click "save-as") https://raw.githubusercontent.com/colga ... Layout.diy
EDIT: Updated with bias and FET changes.
EDIT 6/4/19: Fixed driver board from 820k to 820ohm
Edit 6/14/19: Removed attachments to encourage downloading the latest layout from the GitHub link above.
I'm looking for a peer review of my layout and any feedback as I'll be building this soon Thank you in advance!
NOTES
- V1B LNFB wiring is following the hand drawn schematic
- High filter cap changed from .003uF to .002uF like SSS #004
- Bias adjusted to utilize 60v tap on PT
- v4a to reverb return cap changed from .003 to .002s per SSS #004
- FET resistor divider changed from 220k/8.2k to 150k/9.1k for higher FET output (per Sergio's findings)
- Presence added with 2K trim pot. Resistor change from 270R to 390R to accomodate presence
- 6.3v Heater wires to preamp tubes not drawn
Ryan
Hi Ryan, Im unable to open the "full lay-out pdf". Maybe its on my computer specific...
Oh no!! That's not good... Attaching a JPG
EDIT 5/23/19 (updated JPG to reflect bias changes & FET)
EDIT 6/4/19 Fixed 820 ohm resistor value (was 820k by accident)
EDIT 6/14/19 Removed attachment to encourage downloading the real-time latest https://github.com/colganr/steel-string ... and%20PDFs
Ryan
Take a close look at that bias supply.
Ah yes. Just realized the classictone PT accommodates a 60v tap too. I see the cap is backwards as well Adjusting...
EDIT: adjusted and re-uploaded layout to previous post
Ryan
Can you post the schematic that you are using to make this layout?
The signal entrance at the Fet board has to be on the other end of the 100pF-1M combination.
Sure! I used each of the schematics/layouts in this postmartin manning wrote: ↑Thu May 23, 2019 2:57 pm Can you post the schematic that you are using to make this layout?
&pompeiisneaks wrote: ↑Wed May 08, 2019 5:46 pm ======================
#002:
https://ampgarage.com/forum/download/file.php?id=54112
Schematic: https://ampgarage.com/forum/download/file.php?id=54132
Original hand drawn one from above: https://ampgarage.com/forum/viewtopic.php?f=5&t=17827
Layout by Aaron:
https://ampgarage.com/forum/download/file.php?id=24378
gutshots of a clone of 002: https://ampgarage.com/forum/viewtopic.php?f=4&t=21508
#004
Gut shot:
https://ampgarage.com/forum/download/file.php?id=54109
Layout: https://ampgarage.com/forum/download/file.php?id=54142
Thank you and updated!
Ryan
I believe slucky's comment was referring to the cap polarity; the bias supply from the HT was correct per the schematic.
