Primary impedance of original jtm 45 ot?
Marshall Amp Discussion
neskor
Re: Primary impedance of original jtm 45 ot?
Post by neskor »
If I apply 400hz AC signal 1V RMS on secondary, on primary I'm getting 26.65V RMS, so it should be OK with 6.5K/8R relation
neskor
Post by neskor »
If put all the results in this online calculator step-down ratio looks OK
https://www.hagtech.com/loading.html
bepone
Post by bepone »
neskor wrote: Sun Oct 15, 2023 5:24 am With 1Khz C settings and from Ub+ to secondaries I'm getting 1440pF
ok this is fine
neskor wrote: Sun Oct 15, 2023 5:24 am If I apply 400hz AC signal 1V RMS on secondary, on primary I'm getting 26.65V RMS, so it should be OK with 6.5K/8R relation
if you get 28.65 then is ok, 28.65*28.65*8=6k5..
but ill try also this method today :mrgreen:
pdf64
Post by pdf64 »
neskor wrote: Sat Oct 14, 2023 5:53 am
Have you checked the high frequency to ultrasonic frequency and phase response of your’s?
Mine has a weird resonant peak and phase shift around 40kHz.
I didn't
I don't have balanced signal generator, maybe runing the secondary with SG and solid state amp will work, but never tried.
I think the only valid measurments will be if we put OT in the circuit.
I don’t see that a balanced sig gen (or excitation driver) is needed to check an OT’s response, ie when connecting to the primary.
That can be verified by comparing the results to the response at the primary when driving the secondary.
The response in circuit will be affected the the other contributory factors involved with the amp’s open and closed loop performance.
Though the resonance I mentioned previously was evident when checking the OT with a sig gen and scope, or in the amp circuit open loop response.
Closed loop, presence at minimum, the circuit was unstable at around the OT resonant frequency.
