Bassman Chassis 1959 - What is under the hood ?
Fender Amp Discussion
Raja_Kentut
Post by Raja_Kentut »
Hello folks,
I'm currently planning my next project. It's going to be a Bassman 5F6-A.
I have now discovered pictures where there is a metal cover on the top of the chassis. My question: What is under the hood?
viele Grüße,
Raja
Nothing is better than an unexpected discovery that brings you happiness!
gonzomode
Re: Bassman Chassis 1959 - What is under the hood ?
Post by gonzomode »
B+ filter capacitors, I think it‘s called doghouse.
Gruß,
Josef
bepone
Post by bepone »
it is possible tu buy everywhere ie. tube town ..
maxkracht
Post by maxkracht »
You can also relocate some or all of those caps to the main board for an improved ground scheme if you are planning to build your own board, though probably a bit tight in a tweed style chassis. Larger chassis are more fun to build in, if the tweed-era chassis aesthetic isn't important to you.
Raja_Kentut
thank you all for the answers!
So no „hidden secret“ is there…
I‘ll build my own chassis, big enough to place all into it. (as one of my idols said: „Form follows function“).
I want the sound, not the appearance. If it's in keeping with the era, I'm happy to make compromises. For example, I almost only use point-to-point wiring, and I let my imagination run wild with the cabinets, but I stick roughly to the dimensions and colors of the time.
maxkracht wrote: Thu Nov 09, 2023 5:32 pmYou can also relocate some or all of those caps to the main board for an improved ground scheme if you are planning to build your own board, though probably a bit tight in a tweed style chassis.
Modern caps are much smaller than the 1959 originals, so it's relatively easy to put everything inside.
maxkracht
Post by maxkracht »
martin manning wrote: Thu Nov 09, 2023 7:47 pm Modern caps are much smaller than the 1959 originals, so it's relatively easy to put everything inside.
Certainly doable, and possibly easy, depending on your skill level/dexterity. I do have some shockingly small 10uf 500v nichicons. Still a lot tighter than a BF/SF chassis, though I guess potentially more suitable for a point to point layout.
Traynor
Post by Traynor »
Just a heads up, the 5F6A schematic is not the most common built Tweed Bassman. Do some research, the tone stack changed over the years.
Raja_Kentut
thanks Traynor, I will start with this circuit diagram. (see below)
If you have links to other versions, I would be grateful for them.
I meanwhile believe that there is no such thing as "the" tone, as can be seen from the fact that the voltages in the circuit diagram are specified as +-20%, and the PI resistors that are supposed to be particularly accurate still at 5%…
So the best (individual) solution will ultimately be found by trialling.
Nevertheless, I always want to stay close to the original...
I will build a head, at the moment there is a 20W class A amplifier in the cabinet with a transmitter tube from the old GDR :mrgreen:
If my budget allows it again (man, the components have become expensive!) I will build a 4x10" loudspeaker box with the original dimensions I have got from this forum. The neighbors will be very pleased…
The schematic you have is AFAIK the only one available for 5F6-A. Photos of vintage amps show that in production the tone stack used a 100k slope resistor (in place of 56k), and 100n bass cap (in place of 20n), and that the PI tail resistor was 6k8 (not 10k).
Raja_Kentut
thank you, I‘ll try that values. When I‘m done with this build, I‘ll post the sound samples of both versions…
WhopperPlate
Post by WhopperPlate »
martin manning wrote: Sat Nov 11, 2023 7:44 pm Photos of vintage amps show that in production the tone stack used a 100k slope resistor (in place of 56k), and 100n bass cap (in place of 20n)
And some photos show the 20n and 56k values
I have quoted another post on a different forum .
“Fender used 3 different setups:
- 250pF, 0.02µF, 0.02µF
- 250pF, 0.02µF 0.1µF
-250pF, 0.05µF, 0.1µF
I've heard conflicting stories about which was "the most common setup" though all accounts seem to agree the 0.02µ/0.02µF was the least-common.”
Charlie
Another data point is the Fender reissue Bassman, which one could assume is the result of some study on their part.
Raja_Kentut
ok, thank you very much,
now I'll take bets on which one sounds best :lol:
bepone
Post by bepone »
it is cca 1min 30 sec if we count from cold iron to heat up to replacement of the component in the tone stack in the point to point circuit.
for all the options less than 10 min with sound test included :mrgreen:
usually i go with 20nf + 20nF but i replace one of the cap for sozo to get some mojo :wink:
