2Watt_BluesExpress_Version1 by timohp
Hi,
here are the requested docs!
Have fun and rock!
Timo
Have fun and rock!
Timo
Re: 2Watt_BluesExpress_Version1 by timohp
nice, thanks.
What PT did you use with this?
Would this make a good amp for a first attempt at an amp build (with some help from a friend who knows soldering/safety etc.)?
If so, what is the best way to come up with a parts list? Anyone make a "kit" of this amp or a similar low watt trainwreck style amp?
DAYN!!!!!dayn wrote:Would this make a good amp for a first attempt at an amp build (with some help from a friend who knows soldering/safety etc.)?
THis tinywreck should be easy enough to build... but it may be a little wierd to work on for a first project... a 5f1 is my fave 1'st time project... but if you wbere a 5f1 fan you wouldn't be researching wrecks!
thanks ODwan. Should make for a nice little project.
Hi ODwanODwan wrote:Hi,
Have fun and rock!
Timo
I'm thinking of building the Tiny Tube Express to the design that you posted.
I'm in the U.K where our mains voltage is 235 -245v, is it possible to do away with using a PT completely as the mains voltage is so close, this would cut down the build costs and size considerably, obviously I'd still need to rectify, sorry if this is a stupid question I'm a relative noob at this, I've only built one amp before.
Cheers Andy
hi andy, i'm a noob too, but this is a pretty serious question that you're asking - doing away with the power transformer means doing away with the galvanic isolation that could protect you from shock. in what we (biomedical engineers) call a primary fault condition, you could end up directing the entire wrath of mains voltage onto the chassis or your ground, and there is generally a very high chance of electrocution. a few people have done this sort of thing, but do not recommend it. i would especially not recommend it if you are a beginner, since it is extremely dangerous!maxfac wrote:Hi ODwanODwan wrote:Hi,
Have fun and rock!
Timo
Cheers Andy
there is a simpler and cheaper way to work around the expensive PT - using two 12V transformers with adequate current resources in a back-to-back configuration. that way, you can use 12V to heat your tubes, and get 230V out of the second transformer for B+. cheers.
In the interest of full disclosure, I am Animal Factory Amplification.
I'll second this! A mainstransformer is an integral part in any tube amps safety! Try that back-to-back transformers or sometimes there are cheap line isolation transformers available. I have used a small transformer from http://www.die-wuestens.de/ that is quite cheap. They chip to GB, too.flood wrote: hi andy, i'm a noob too, but this is a pretty serious question that you're asking - doing away with the power transformer means doing away with the galvanic isolation that could protect you from shock. in what we (biomedical engineers) call a primary fault condition, you could end up directing the entire wrath of mains voltage onto the chassis or your ground, and there is generally a very high chance of electrocution. a few people have done this sort of thing, but do not recommend it. i would especially not recommend it if you are a beginner, since it is extremely dangerous!
Timo
Looks nice!
I experimented with a low watt 12au7 trainwreck a few years ago. Only I implemented a LTP PI and NFB loop instead. Have you tried anything like that? I wonder how it would compare.
Thanks for the heads-up on the safety aspect of my question, I think I'll stick with a PT, my wife and kids would miss me I think ? The thought also occured to me after I'd posted that I'd still need a PT for the heaters so I'd probably not save that much real estate on the chassis anyway.flood wrote:hi andy, i'm a noob too, but this is a pretty serious question that you're asking - doing away with the power transformer means doing away with the galvanic isolation that could protect you from shock. in what we (biomedical engineers) call a primary fault condition, you could end up directing the entire wrath of mains voltage onto the chassis or your ground, and there is generally a very high chance of electrocution. a few people have done this sort of thing, but do not recommend it. i would especially not recommend it if you are a beginner, since it is extremely dangerous!maxfac wrote:Hi ODwanODwan wrote:Hi,
Have fun and rock!
Timo
Cheers Andy
Andy
Sorry I know this is probably a noob, question, but if anybody has a link to a suitable power transformer or part #, that would be great.ODwan wrote:I'll second this! A mainstransformer is an integral part in any tube amps safety! Try that back-to-back transformers or sometimes there are cheap line isolation transformers available. I have used a small transformer from http://www.die-wuestens.de/ that is quite cheap. They chip to GB, too.flood wrote: hi andy, i'm a noob too, but this is a pretty serious question that you're asking - doing away with the power transformer means doing away with the galvanic isolation that could protect you from shock. in what we (biomedical engineers) call a primary fault condition, you could end up directing the entire wrath of mains voltage onto the chassis or your ground, and there is generally a very high chance of electrocution. a few people have done this sort of thing, but do not recommend it. i would especially not recommend it if you are a beginner, since it is extremely dangerous!
Timo
Also I know that the wires of a PT are color coded, so how would the different colors fit the numbers listed on the power section layout?
I do alot of work with perfboard and am also wondering if you think I could do the whole layout on perf? Never used turretboards before.
Whale Meat.....Its whats for dinner.
- dorrisant
did you ever get a transformer?
you could look at just about any of the tube amp parts suppliers and find one. look for a pt for a champ or something small like that... this circuit won't draw many mAs so you don't need much. a decent pt will save you a lot of trouble in the long run 'cause it has the filament voltage as well... and probably won't cost too much either.
i was going to post a link to triode electronics but something seems a little wonkey with their site...
other option... i found an old crescent reel to reel tape player at a flea market. had a complete tube amp with a se 6k6, two siemans preamp tube (sweet!) and an indicator eye tube... all for the awesome price of $5... can't beat it with a stick!
good luck!
tony
good luck!
tony
Anyone got any build pics? I'm tempted to have a crack at one of these, we are 240v in New Zealand as well ![Smile :)](./images/smilies/icon_smile.gif)
Whatever you do, use a power transformer! Use a pair of low voltage transformers back to back, rip one out of an old valve radio..whatever
Otherwise, all it takes is a miswired power point and you could possibly have all 240 of those volts on your guitar strings
![Idea :idea:](./images/smilies/icon_idea.gif)
![Arrow :arrow:](./images/smilies/icon_arrow.gif)
Hi there!jeremyb wrote:Anyone got any build pics? I'm tempted to have a crack at one of these, we are 240v in New Zealand as well
see my blues express combo:
http://ampgarage.com/forum/viewtopic.php?t=13456
Enjoy!
Ciao
Martin
