Trainwreck Anna Real or Clone?
Re: Trainwreck Anna Real or Clone?
I'm no expert but, The name , the fonts look wrong to me, to neat
I work at a pawn shop and I would sell one for as much as the market would allow. Wish Someone would bring one in to me to sell.ChrisM wrote:I wonder how much a pawn shop sells a "real" TW for?
I have seen some cool items at our stores.
Pawn shopping used to be fun.
I agree....Reeltarded wrote:Pawn shopping used to be fun.
Based on looking at it if we still have doubt Anna is a clone. Cross referencing the list actual Anna is not an express.
My Daughter Build Stone Henge
- geetarpicker
No bud chassis, wrong font label maker, wrong corner joints on cab, wrong jacks, wood logo (come on!), and the wood burning and even choice of wood itself is unlike any real wreck I've seen... CLONE!
To me, the most obvious sign it's a clone is the use of those crappy plastic jacks for the speaker outputs. I've only seen KF use Switchcraft in his builds, so this is immediately a red flag. Of course the cab is wrong too!
Cliff Schecht - Circuit P.I.
Doesn't mean it couldn't sound nice. Just not worth stupid money.
- LeftyStrat
I was also going to add this. If it sounds good and the price is reasonable, go for it. Just don't plop down $25k for it.Firestorm wrote:Doesn't mean it couldn't sound nice. Just not worth stupid money.
Not knowing the original builder would also discount the value a bit. You could probably get several builders on here to build you one and they would stand by their work. Find someone on here that is close to you and they could also probably tweak it to your liking.
- LeftyStrat
Ever now and then you can still find treasures. Your better off visiting the pawn shops that don't deal in musical instruments. They're less likely to know the value of things. Of course eBay has sort of allowed everyone to determine a ballpark value for things. But the shops with less emphasis on musical gear get less traffic from musicians, so some good gear might languish on the floor long enough for them to lower the price to free up space.jeff12 wrote:I agree....Reeltarded wrote:Pawn shopping used to be fun.
I still haven't come across that left-handed '59 Les Paul for $100, but I keep looking (and buying lottery tickets).
Absolutely a clone. Those wooden, lazer-cut logos were made by TAG member Lonely Raven in Illinois. A real TW would have a black & white plastic, flat logo.
If we really want to get knit picky the transformer is a heyboer clone model. (Wire color- coming out of the transformer is not correct to pacific 11415).
The 9 pin tube socket is held in by a gold screws.- never used in authorized TW. The 9 pin tube sockets are not correct the lock pin is to low. The tube socket covers are not correct, they should cover the lock pin when on. The cabinet does not have a tube chart. Chassis is the wrong material, build construction, and finish. As noted dymno labels are wrong font and spacing/tape. The fuse holder is not correct (size,style,manufacture) the chassis stamp is to large to defined and missing the date stamp.
The cabinet is not up to the standard of build quality, mostly in finishing work. Corners routing, jointing, etc. (TW has used woods other than cherry).
Logo has never been wood. As noted the faceplate is CNC not pyrograph.
The swiches and pilot light are not correct. Jacks as noted are not spec though several OEM TW do have cliff jacks on the input.
Ok I'm bored its a clone
If it doesn't have the flimsey hammond chassis, a cutoff broom stick handle (Dowel) between the trannys and also one in side the chassis with a bolt going through it to help support the trannys than it is definately a clone.
The most troubling thing is that someone is trying to pass this off as a real TW. On the other end, I think its fine for someone to make a replica, but it should be clearly labeled as such, and this is especially true if it's got all period correct parts. It shouldn't be necessary for a buyer to do a lot of research to discover if it's the real thing or not.
