Rocket Power Dissipation
Re: Rocket Power Dissipation
When I measured mine, 300v B+, RJ Heyboer Rocket transformer it was 20-22 watts clean (can't remember the exact figure) 26 watts at full clip.
Good point, I will keep that in mind.Cliff Schecht wrote: The point at which the cathode cap makes the output stage sound like a fixed bias amp is usually much smaller than the cap value you'd need to require a 70% bias point.
Eh, I don't know about your guys 15-20W measurements. With that low of plate voltage I at least get 25W before break up and maybe 35-40W full tilt.
Voltage squared divided by resistance equals wattage. I measure my output while I play to give me a rough idea of a real world measurement
"It Happens"
Forrest Gump
Forrest Gump
Ah, okay that's fine, but no one actually measures output power that way so it's hard to relate it to anything.passfan wrote:Voltage squared divided by resistance equals wattage. I measure my output while I play to give me a rough idea of a real world measurement
I looked up an old post of when I measured the power and it was actually 28 watts clean, 32 at full clip. So, you're right, my memory was bad!Gaz wrote:Eh, I don't know about your guys 15-20W measurements. With that low of plate voltage I at least get 25W before break up and maybe 35-40W full tilt.
Yeah, that makes sense, I just didn't want t throw off the OP ![Wink :wink:](./images/smilies/icon_wink.gif)
