[help] komet 60 transformer spec.
hello all member of ampgarage.
It's my first post in this forum. I have a plan to build komet 60 amp, but have some problem about transformer (PT,OT, and Choke).
Anyone can give the specs about all transformer in komet 60?
warm regards
dewa
warm regards
dewa
Re: [help] komet 60 transformer spec.
power: hts-8593 rh365pt
output: hts-5526 1rh, 5.8k pri.
choke: hts-7750-1 10H/200ma
thx a lot mr. Fowler.
BTW i try to find spec all the heyboer trans, but their site is broken.
can u tell me about DC resistance for chokes?
regards
dewa
regards
dewa
- RJ Guitars
Deewa - I have one of those chokes here and measured the DC resistance with my ohm meter at 65 ohms - is that what you needed?7deewa wrote:thx a lot mr. Fowler.
regards
dewa
thanks,
rj
http://www.rjguitars.net
thx a lot mr. RJ
Anybody know the best place to purchase these? The HTS numbers don't cross-reference easily to Mojo or Weber.
Heyboer.
Allyn may have some, or possibly RJ.
FYI, I contacted Heyboer for a quote. It took them less than a day to respond. $245 and approx 2 weeks delivery.
- RJ Guitars
I have an exchange going with Heyboer to see what the availability is. i don't typically buy less than a dozen of any one tranny. In this case we'll see what they have available or if they will make a small run on them. They often sell directly to individuals but most of my experience with them makes it worth the trouble for me to place a larger order. I'll let you know what they say.
rj
PS FWIW - Edcor on the other hand seems to have a preference for winding trannies one at a time. It's a slower process requiring an engineering fee and usually a lot of phone calls but they do make fantastic products once the educational part is taken care of.
rj
Hey RJ,
You mind seeing if it's a problem for Heyboer to wind one of those PT's for Aussie mains? That'd be 240V/50hz.
__________________________________________
Cheers and Beers.
Cheers and Beers.
they have dual primaries--------so it's already done for you. rhBeerman wrote:Hey RJ,
Re: power spec.s
dual 120v primaries with 100v taps---allows for various export pri. voltage hookups; 365-0-365n.l. @ 250-300ma; 5v@3a; 6.3v@5-6a; there's around a 70v bias tap from the hv sec wind.lumox0013 wrote:anyone know what the power tranny specs are? thanxx
so if you have a jtm45 power trannie laying around, you can use that and it'll get you close----they're about the same size, but you'll have to roll your own bias supply off the hv sec leg. rh
thanxx
thank you for the heads up kind sir I have wanted to try one of these but dont got the shills for custom trannys one of my boneyard peices might work.
Live , Love , Learn
