dimensions of bias supply board?
where might I find the measurements for the bias supply board? looking to pick up some board material to start an express build......want to make sure it's wide enough. Thanks a million
Re: dimensions of bias supply board?
thanks alot......I plan on making the boards out of rosewood with turrets......I like to be different
- MooreCowbelle
Rosewood!?!?
Wow, that would be different. As long as it doesn't burst into flames...
And the oils don't conduct current?
Alex
TheCageWreck and Glaswerks SOD100
Only if it's ironwood. LOL.
Actually was thinking the same thing myself, but imagine the voltages would have to be higher??
The power supply board is 4 7/8" long and 3 1/2" wide with a 1/4" offset to clear the filtercaps.
You just got to post some pics of the boards when you get them done.![Cool 8)](./images/smilies/icon_cool.gif)
Hope this helps!
Hope this helps!
dumble and two-rock use rosewood without problems
I'd bet it's Formica.funkmeblue wrote:dumble and two-rock use rosewood without problems
![Wink :wink:](./images/smilies/icon_wink.gif)
![Laughing :lol:](./images/smilies/icon_lol.gif)
dumble used formica ...lol DON'T use wood of any type for a circuit board it's extremely heat sensitive will dry out and then stuff will get loose....can you say ZAP! pop...wtfbbq?! you can use the crappy wax impregnated cardboard fender used to use...but i prefer phenolic or epoxy and i like turrets gets a good solid mechanical conection so the solder(whic isn't weld , lol) just cunducts...happy building. ![Wink :wink:](./images/smilies/icon_wink.gif)
