GT Bias tool
GT Bias tool
Has anyone used a Gr__ve T_be bias tool to bias your amp?
Re: GT Bias tool
Why the name redaction?
I have never used that one. I have a CompuBias and love it.
Re: GT Bias tool
I have owned this for several years and have used it occasionally when retubing amps, I just wondered if anyone has used one in biasing their "clone".
I read through the archives and have seen the numerous posts on biasing the amp, and have absorbed what has been established and will go ahead and use by GT bias tool.
Re: GT Bias tool
The name redaction was because I am not endorsing any products for any manufacturer.
Re: GT Bias tool
I have not.dmouse wrote:Has anyone used a Gr__ve T_be bias tool to bias your amp?
I use the Weber Bias Rite.
http://taweber.powweb.com/biasrite/br_page.htm
Re: GT Bias tool
This isn't the Gear Page - you don't have to be that politically correct here.dmouse wrote:The name redaction was because I am not endorsing any products for any manufacturer.
Re: GT Bias tool
Ok, thanks.
Re: GT Bias tool
what your thoughts on the bias rite? I have the version with optional switching and noval / octal. It's never really worked well for me. I gave up on it years ago. Learned to bias with a scope and transformer shunt. Now more times then not I a pair of compubias.NickC wrote:I have not.dmouse wrote:Has anyone used a Gr__ve T_be bias tool to bias your amp?
Weber's bias calculator is a handy tool
My Daughter Build Stone Henge
Re: GT Bias tool
It gets me in the ballpark. I have a friend that works on tube stuff all of the time,ie.guitar amps, high end audio, Mac's, Dynaco, Eico,etc.. who likes tube stuff and I will run it by him to fine tune and do some tube rolling.
Re: GT Bias tool
selloutrr wrote:what your thoughts on the bias rite? I have the version with optional switching and noval / octal. It's never really worked well for me. I gave up on it years ago. Learned to bias with a scope and transformer shunt. Now more times then not I a pair of compubias.NickC wrote:I have not.dmouse wrote:Has anyone used a Gr__ve T_be bias tool to bias your amp?
I have the same model as you, two octal and two noval connectors.
I hook it up, take readings and plug them into the Weber Bias Calculator. Then adjust to the recommended value(s). I'm a novice at amp building/servicing. I don't know near as much as most folks in this forum. I'm happy if the amp works, sounds decent, and the tubes don't red-plate ... so by that measure the Bias Rite has served my needs.
