Two years ago, I knew nothing about amp building. Found this forum, got bit by the bug, and now have several great amps. Thought I would share my current build in-progress and ask for any changes I should make. I am still waiting on some missing parts, but this is where I am currently at with the build.
Chassis and iron from R.J. All other parts are what I had on-hand.
Thanks for all the info and advice you guys provide.
In my case, volume difference depends on mastervolume setting. I installed a bootstrapped master volume to compensate for different power scale settings. If it is set for easyly clipping the PA, the difference in volume is not significant. If set for super clean gradual mode, then the difference is huge.
Thanks for the replies. It would be handy if the footswitched function could be used as a lead boost but if the volume difference is that drastic.... I'm using a class A PP PA which should have a lot less headroom than the EL 34's w/ high plate voltage.
Hey guys, I've been sidetracked on another build, finally got this amp finished with the exception of V1 coax. What coax would be good for this build? All I have is some very small diameter coax, doesn't look as beefy as what is used on these amps.
Also, if anything looks wrong, please let me know.
Thanks for all the help.
-Jim
