If anyone is bored or needs a good laugh, would you mind taking a look at this layout and see if anything is just plain stupid.
I was doing a layout for a Liverpool, then a rocket/Zwreck and then down the concorde rabbit hole and threw this together last night over a Bourbon or two. I recently built a 2 channel marshall that had the Plexi/parallel input and it really sounds good, so i figured why not try and throw that into a wreck style build. Then I remembered the Connie used this, although i don't know for certain, but from what i've read...maybe? At this point I'm not sure anything about this is a wreck other than the power end of things, but I'm bored, have parts that need built and a bottle of Redbreast to sip on tonight.
the NFB / depth circuit is in there for testing and possibly putting on a switch, but again, not trying to copy anything here, just not make smoke.
Cheers
sanity check
studiodunn
sanity check
