Hammond 12AU7A tubes
Plague
Post by Plague »
My Hammond 12ax7 just went bad in my liverpool.
What are the 12Au7a's like?
What are some other pre-amp tube recommendations you guys have?
By the way, I have 2 12Au7a's that my builder gave me. Not sure if I should try them or not.
doctord02
Re: Hammond 12AU7A tubes
Post by doctord02 »
12au7's are very different both gain and current wise. While they have the same pin-out, they will sound quite different. This might help you:
http://thetubestore.com/gainfactor.html
fishy
Post by fishy »
Some comments here from a previous post about 12Au7s and a Liverpool.
http://ampgarage.com/forum/viewtopic.ph ... +liverpool
Plague
So, if I were to replace all 3 pre-amp tubes...
Post by Plague »
doctord02 wrote:12au7's are very different both gain and current wise. While they have the same pin-out, they will sound quite different. This might help you:
Thats chart is awesome! Thanks.
Should I get three of the same?
Or buy 1 tung-sol, 1 mullard, and one tung-sol gold and interchange them to see what sounds best?
Never done this before. Any advise would be greatly appreciated!
korngold
Post by korngold »
What did you end up doing/going with, and in what order? Does it sound as good as before?
Plague
Post by Plague »
korngold wrote:What did you end up doing/going with, and in what order? Does it sound as good as before?
Learned a bunch about old tubes since this thread!!
Here is where I ended up...
V1 Tungsram 12ax7
V2 GE Electric 12ax7
V3 Mullard 12ax7
If you would like to hear the difference listen to the 2nd track on our myspace player. I put a couple minutes up of a jam/song were writing with the new tube arrangement...
www.myspace.com/theinbetweenoc
listen to "Tread On Disaster" New tube arrangement...
"Gateway" is the old arrangement of tubes.
Tyler
