Did a clip today of my ceriatone expression, toneslut output, niks power, mallory od's, sprague electrolytics, rca 6v6, bugle boy/telefunken/rca long blackplate, celestion 50 watts in 2-12 closed back mic with sm57 close, sm57 10' away. Les Paul 57 historic.Neck pickup vol 3 rythmn, neck lead first, bridge pickup last. Used carvin 10 channel board into my zoom 4 track sd recorder. ppimv at 12:00, vol 11:00, treble 1:00, mid 11:00, bass
9:30, presence full/500pf.
ceriatone expression clips 6v6's
Re: ceriatone expression clips 6v6's
Well Now... i like it!
You've got soul i can tell...
Keep up the good work
Thanks tt...people have been asking about using 6v6's and I wanted some sort of clip up for reference.
Man, I like the way that sounds. Has that steroidal blackface deluxe thing happening.
Cool clip.
Cool clip.
Randal
Blues Junkie
Blues Junkie
Thanks RH, the mp3 clip doesn't reproduce the bass this amp has, it does the blackface deluxe/tweed bassman feel well at a nice volume level even with the ppimv.
- PlinytheWelder
Which OT are you guys using for 2 6V6's in an Express? I'm leaning towards the Toneslut Experimenters with 5200 and 4300 Ohm windings. I suppose that the 6600 Ohm tranny would be more optimum for dual 6V6's, but OTOH I could just change speaker taps.
Also, is the "standard" 6600/5300 OT still available? I don't see it listed on the Toneslut order page.
The JJ 6V6 and KT-77 are 2 of my favorites for current production tubes and I would like to be able to use both along with EL-34's.
Thanks!
Thanks!
i use an old 35 w Pacific tranny lifted from a Western Electric P.A. but don't remember the specifics...works well.
"If I might suggest, I have Vintage Spec trannies in stock that are a
match to the ones in Franchesca. That means M19/26 steel instead of the
M27 used in the standards, and 6600 ohm only. They are smoother and less aggressive than the standard, and the trade is a little more sustain and harmonic feedback that makes an Express such a fun amp."
I used the the vintage transformer to replace my ceriatone ot per the recommendation from TS.
