The Matchless Spitfire is a good circuit and I used one for gigging for several years. To cut through the mix I simply relied on my pedal board effects to help me through.
from your pictures on your version of the PPMIV I don't see the usual 2M
resistors across the lugs, how did you wire that up?
I see lug 1 to ground and ??
I want to build a Spitfire and maybe add an EF86 channel
and employ your MV
I also listening to your 1986 Plexi Build video....Wow
joeboo88 wrote:fusionbear: nice job and it sounds awesome!
and employ your MV
thanks in advance, Joe
One lug goes to ground and the other goes to the input of the power tubes. There is always a 250k reference to ground for the screens. No need to use extra resistors. The wiper is the input.
