Tl806 1x12 cab
ampmike
Tl806 1x12 cab
Post by ampmike »
Anybody have a good drawing plan for one of the Theile cabs.Like to make one and I know you have to build it right down to every detail for it to sound right,Thanks
Custom Built Amps for Sale!http://faithamps.weebly.com/
norburybrook
Re: Tl806 1x12 cab
Post by norburybrook »
here you go :D
tl606.pdf
(296.42 KiB) Downloaded 368 times
M
alkuz1961
Re: Tl806 1x12 cab
Post by alkuz1961 »
Marcus, you are slightly mistaken, these are the blueprints for the 15" speaker cabinet.
TL806_Builders_Plans.pdf
(409.8 KiB) Downloaded 367 times
norburybrook
Re: Tl806 1x12 cab
sorry, yes indeed...I was multi tasking :D
I have one of these cabs.
They're too small to put a regular size amp head on though which ever way round you put it so I never use it :D It would 'look' good with my Tweedle Dee head :D I should give it a try.
M
andresound
Re: Tl806 1x12 cab
Post by andresound »
Great sounding cabs
ampmike
Re: Tl806 1x12 cab
Post by ampmike »
Thanks guys,I was thinking about making one,they look pretty simple,I got a little Friedman head PT20 and thought it might be cool having the speaker cabs.Thanks again :D
norburybrook
Re: Tl806 1x12 cab
ampmike wrote: Fri Aug 23, 2019 1:08 pm Thanks guys,I was thinking about making one,they look pretty simple,I got a little Friedman head PT20 and thought it might be cool having the speaker cabs.Thanks again :D
Mike, they're really heavy for what looks like a small cab. There's a lot of 3/4 ply in these and combined with an EVM they go to make a heavy speaker cabinet.
Just warning you as you mentioned a small amp :D I'm going to try mine with my tweedle dee and I'll report back :D
m
Bill Moore
Re: Tl806 1x12 cab
Post by Bill Moore »
I also have some plans I modified from the 806Q for a 2-12, (works great as a mid PA speaker, or guitar).
alkuz1961
Re: Tl806 1x12 cab
Post by alkuz1961 »
I've build ported cabinets several times, any required size, based on Theile cabs. In fact, you can change the aspect ratio, but without changing the internal volume. Only two parameters are really important - the internal volume and the size of the port opening. They determine the resonant peak in the bass range.
By the way, in my research I found that that the Bogner CUBE cab has the same resonance frequencies. I also repeated its design and it sounds very good. But I think CUBE looks nicer than TL806
Tony Bones
Re: Tl806 1x12 cab
Post by Tony Bones »
alkuz1961 wrote: Fri Aug 23, 2019 8:27 pm I've build ported cabinets several times, any required size, based on Theile cabs. In fact, you can change the aspect ratio, but without changing the internal volume. Only two parameters are really important - the internal volume and the size of the port opening. They determine the resonant peak in the bass range.
Does the port length also matter? It affects the port impedance, probably in a frequency dependent way. The only way I can wrap my head around these things is by understanding that they can be expressed as analogous electrical or mechanical systems. See, for example, Olson (1943), Dynamical Analogies.
alkuz1961
Re: Tl806 1x12 cab
Post by alkuz1961 »
Tony Bones wrote: Fri Aug 23, 2019 9:52 pm Does the port length also matter? It affects the port impedance, probably in a frequency dependent way. The only way I can wrap my head around these things is by understanding that they can be expressed as analogous electrical or mechanical systems. See, for example, Olson (1943), Dynamical Analogies.
Yes, you must to observe the proportions between the area and depth of the port tube to save the parameters of the cabinet.
In our case, we can leave port dimensions unchanged, if we do not change the volume of the box, but only change the ratio of its sides.
For example, changing the size of the cabinet, which I show in my pictures, I left the initial height (and thus I left unchanged the parameters of the port), increased the width to the size of the amplifier, but reduced the depth to maintain the same volume.
But if you need to change the size of the cabinet and its volume, you will have to recalculate the port. There are some software like BassBox Pro or JBL Speakershop. You can enter the dimensions of the source cabinet, determine the parameters of its resonance, and calculate a new cabinet by changing the size of the port, to obtain the required parameters.
ampmike
Re: Tl806 1x12 cab
Post by ampmike »
Some great info here guys.So is the baffle 3/4 plywood for the speaker mounts ?I can see the rear panal is 3/4.Your right it is a decent amount of weight.Somethingfor me to think about.And the corect speaker is a EVM?They run about 250.00 used if Im not mistaken.Thanks
Geeze
Re: Tl806 1x12 cab
Post by Geeze »
I built a pine TL806 for a friend - his band swears it's his best sounding cab. I used home supply 'pine' edge glued with a 1.25" walnut trim [just had to add some class]. After 6 years it's still unfinished as he's paranoid he'll change the sound. I believe its the well pummeled EVM12L just doing it's thing.
norburybrook
Re: Tl806 1x12 cab
you can use a 12L or a 12 S, I've used both and they sound the same to me.
The Dumble ported 'Larry Carlton' cabs are great, they #re very similar to that bogner cube only the ports are either side. Do a forum search as I've done a couple of build threads. They sound great.
The original 806 is very deep so making it wider and less deep keeps the internal volume but makes it more useful to sit a wider amp on :D
M
stelligan
Re: Tl806 1x12 cab
Post by stelligan »
alkuz1961 wrote: Fri Aug 23, 2019 8:27 pm By the way, in my research I found that that the Bogner CUBE cab has the same resonance frequencies. I also repeated its design and it sounds very good. But I think CUBE looks nicer than TL806
Very interested in your take on the Bogner cab. Love TL boxes and ported cabs in general.
Had some EV loaded TL boxes since the 70s. The Hermida ported cab is a nice cab also and more head perching friendly.....
