Power Supply
Power Supply
A plate and screen supply is a common element we all use.
I've used this several times. SiC Schottky diode rectification and a capacitor multiplier make for a great clean power supply. Not too stiff, just very low ripple. It also takes advantage of high quality, compact snap in elytics as well.
I can't take credit for the design. It's elements of other people's work. Merlin discusses cap multipliers in his PS book, I added the SiC rectifiers. The sag resistors and snubber caps are from John Broskie - caps probably aren't necessary with the Schottky diodes since there's no reverse recovery.
I've never designed a PCB, but I thought I might try to take this schematic and put it into KiCad.
Fixed errors and ran simulation:
Steve
Re: Power Supply
I'm slowly teaching myself KiCad.
Anyone see any mistakes so far?
Steve
Re: Power Supply
I have no idea what the PX5D is. could you specify more detail? Is it a specific PCB? All Google gives me is a power supply for korg Pandora PX5D.
Re: Power Supply
That circuit cannot work.. you need a voltage divider to ground to set the gate voltage.... Why resistors in series with the diodes??? If used they must be very low value....
Re: Power Supply
I'm wondering about the load. You're showing a 13.8k resistor in the .pdf, so at 400V that would be ~ 29ma. What power amp is this for? Idling at 29ma, a single pentode?
Re: Power Supply
Yep, also wondering what the circuit is for.
But resistors in series with diodes can be useful, makes the on to off transition a little softer and can dampen noise coming from the TX. Quite right, they have to be small unless you're aiming for a current source (handy for sag).
Re: Power Supply
The series resistors are 10ohm, 1watt or so - just to emulate some sag if you wish and can be omitted. The FET circuit is an active filter to reduce ripple - cap multiplier. The transistor after it is for current limiting/soft turn on for B+.
Steve
Re: Power Supply
Steve,
I remember how good a KT88 sounded running in SE/UL with a cap multiplied power supply. Very tight!
Re: Power Supply
It might be a silly question then...
Why put a cap multiplier after sag resistors. Would that not make the time constant a wee bit too long?
Re: Power Supply
The cap multiplier's primary function is to filter out power supply noise / ripple.
It's not a replacement for an inductor - like a gyrator. Sag is the power supply's reaction to load changes.
The cap multiplier does a great job of cleaning up B+ without having a big effect on sag. I've used this type of supply on several amps and it really lowers the noise floor a lot.
I didn't include the sag resistors (transformer's impedence is enough for me) or the caps around the diodes (I used SiC Schottky rectifier diodes, little reverse recovery - pretty quiet by themselves.) I just added them in case I wanted to try them out....
As Colossal noted above, SE and UL amps benefit from really clean power supplies even more so.
Steve
