SOLD OUT PLEASE DELETE
List tube amp related items you wish to sell or trade. Private sales only. No dealers or manufactures.
amplifiednation
Post by amplifiednation »
Hello my TAG friends.
Doing a new run of JM/Wonderland Chassis and eyelet board sets. These have been very popular on the forum the past couple of years and have sold out before they were finished both times we have done them! These will build the JM/Wonderland layout in the Dumble section. These amps are fantastic clean channel masterpieces with a beautiful reverb and relatively easy to build!!
Chassis are in stock ready to ship as of 12/22/22 - I am so sorry for the extended delay...but no longer any wait...we have about 20 sets left.
DETAILS:
  • .080 5032-H32 aluminum alloy
    CNC punched
    Masked for clean ground points
    Silkscreened
    **4 x 4" stainless mounting screws, cage nuts, and washers
    Manufactured in Massachusetts
    You can build a 50w or a 100w into these high quality chassis (or 22w with optional $25 bracket)
SPECS for Wonderland style chassis:
  • 19" x 8" x 2.5"
    18" x 5" mounting holes
    5 noval sockets
    4 octal sockets
BOARDS
  • CNC punched G10 .0625"
    eyelets installed
    4 piece set with power, preamp, rectifier, and rectifier backer
Chassis $199
Boards $99
Shipping $25, +$7 for each additional chassis
$323 for a set...
I will sell some chassis without boards if you want to use your own, or the Tone Geek boards fit perfectly...
DM me here or email sales@amplifiednation.com
Taylor
Last edited by amplifiednation on Tue Jun 04, 2024 11:00 am, edited 4 times in total.
Amplified Nation
www.amplifiednation.com
@ampnation
Bombacaototal
Re: Amplified Nation JM/Wonderland Chassis and Board Sets
Post by Bombacaototal »
Did you ever do this run? I'd be down for one or two
Bombacaototal
Moderators, maybe worth deleting this thread as it seems not being offered anymore?
erwin_ve
Post by erwin_ve »
Bombacaototal wrote: Fri Sep 30, 2022 5:23 am Moderators, maybe worth deleting this thread as it seems not being offered anymore?
The description: Chassis will be ready to ship in October.
jazzbass
Post by jazzbass »
Hi,
I beg your pardon but sometimes the most trivial things are neglected only to realize that they are important. Using an Amplified Nation chassis I need to use three Jack outputs for the three impedances: 4,8,16 Ohm instead of an impedance selector. In order not to burn the output transformer, the Jack outputs must be "closed" or "open". The problem is that only one Jack output will be used while the other two will remain inactive.
Excuse me I have a moment of "I don't remember how it works"
Thanks, Franco
franco mezzalira
Bombacaototal
As we approach end of Oct and there has been no response I am assuming this is no longer available?
professormudd
Post by professormudd »
jazzbass wrote: Thu Oct 20, 2022 6:59 am Hi,
Thanks, Franco
I think I understand your question as to what kind of jacks to use, i.e. switched/shunted vs open/non-switched. I reckon you are supposed to use non-switched tip/sleeve jacks. When you use a rotary switch for impedence, it does not ground the unused taps, it leaves them open.
-Matt
It may very well be that the sole purpose of your life is only to serve as a warning to others.
jazzbass
Post by jazzbass »
Thanks professormudd,
This was the answer I was looking for.
A hug.
Franco
franco mezzalira
amplifiednation
Boards are in....chassis should be ready in a couple weeks. Sorry for the extended delay...
Amplified Nation
@ampnation
amplifiednation
Re: Amplified Nation JM/Wonderland Chassis and Board Sets - IN STOCK 12/22/22
Chassis in stock and shipping today!!
Amplified Nation
@ampnation
amplifiednation
Shipped 11 chassis so far almost all with boards...let me know if you want one!!
Amplified Nation
@ampnation
Colossal
Post by Colossal »
Bump!
amplifiednation
Colossal wrote: Thu Feb 16, 2023 12:35 pmBump!
Thanks Dave!
Still got these in stock!
Amplified Nation
@ampnation
mdlockyer
Post by mdlockyer »
amplifiednation wrote: Wed Mar 08, 2023 11:10 am
Thanks Dave!
Are any of these still available?
amplifiednation
Yes. 5 chassis/board kits remain…
Then a few more chassis with no boards
Amplified Nation
@ampnation
