4th Generation 100 watt
67plexi
Post by 67plexi »
It passed the flame test, all voltages spot on. And it sounds great. And the deep switch is good.
well balanced amp from clean to overdrive and fet. Bias -32.5 6L6GC quad made in USA.
Thanks to all, Steve. :D
LeftyStrat
Re: 4th Generation 100 watt
Post by LeftyStrat »
Awesome! We need clips. I'd love to hear the classic preamp with 100 watt power amp. What kind of filtering in the power supply?
sonicmojo
Post by sonicmojo »
Nice, my favorite amp circuit! Did you add a boost? I notice a second relay on there.
Bryan
67plexi
Post by 67plexi »
Thanks' the first filter stage is 300uf @ 500v x2 = 150uf @ 1000v.
Yes it has a PAB, and 100k overdrive ratio pot. The deep switch shines using the fet with a acoustic guitar. As far as clips go it will take time. I need to build a combo or a head box next.
Steve.
67plexi
Post by 67plexi »
One more photo.
dreric
Post by dreric »
Nice to see you building again! Looks like a cool amp. Is the overdrive ratio the same as the #60 ODSR?
Eric
67plexi
Post by 67plexi »
Eric, On ODSR I used 250k OD ratio and 2MEG2 for the clean ratio
#60 is a killer slide guitar amp it cuts through the mix like no other ODS amp.
Steve.
Looks nice Steve.
Can you tell us about the OD trim pot on the back
67plexi
Post by 67plexi »
Tom, Thank you, It's just a 100k CTS pot to fine tune the overdrive.
Max
Post by Max »
LeftyStrat wrote:I'd love to hear the classic preamp with 100 watt power amp.
Just to avoid misunderstandings:
Most of the original 3rd generation ODS amps don't have a "classic" tone stack but the "pre-classic" tone stack documented in this layout: http://ampgarage.com/forum/download/file.php?id=14344
The "classic" tone stack - documented in this layout: http://ampgarage.com/forum/download/file.php?id=14346 - you'll find in most of the transition generation and 4th generation ODS amps.
AFAIK the transition generation ODSR #0060 (originally in a head cabinet and not yet in Bonnie Raitt's combo cabinet) hasn't originally been built with a 3rd generation "pre-classic" tone stack and a 3rd generation "pre-standard" OD circuit, but has originally been built with a "classic" tone stack and a "standard" OD circuit. Later AFAIK it has been updated to "skyline" specs with some special tweaks. As beeing owned by Jackson Browne and used in his studio AFAIK #0060 is the result of a constantly ongoing updating process anyway.
Cheers,
Max
67plexi
Post by 67plexi »
Max I'm no Dumble expert this new build is a pre skyline eq.
To clear up the confusion #060 ODSR is a older build not this one.
Thanks' for your input, Steve.
odourboy
Post by odourboy »
You should have tinned your copper bus bar - looks way cooler! :wink:
67plexi
Post by 67plexi »
Good one thanks.
LeftyStrat
Max wrote: Just to avoid misunderstandings:
Cheers,
Max
Still trying to understand the terminology.
pre-classic tone stack: 50 watt amps
classic tone stack: 100 watt amps, low plate (some, like #124 were later modified to skinner).
skyliner: 100 watt amps, high plates
Is this correct?
stevlech
Post by stevlech »
The tonestacks are the EQ circuits and have nothing to do with output power.
2nd generation has a 100k slope resistor, caps are 510pf/.01uf/.1uf
and 500k linear/250kAudio/1M audio pots
3rd generation is similar but with a 250k Audio treble pot
Classic tonestack has 100k slope, 330pf/.047/.1 uf caps
250k Audio/100k Linear/250k Audio pots
Skyliner has 150k slope, 2200-500pf/.01/.1 uf caps
250k Linear/250k Audio/500k Audio pots
There is more to it and there are variations, but these values are common amongst several known amps.
I hope this helps.
