The new dumble modded bassman build video series... begins!
5 others liked this
Re: The new dumble modded bassman build video series... begins!
Looking forward to seeing this come together!
Bassman and an Overdrive Special coming together should sound amazing!
Cheers
G
Cheers
G
fred.violleau
Exited here to ! Keep'em comin'!
Fred.
Fred.
Charlie Wilson
3 others liked this
Cool Phil, a couple things. The PI resistor after the 470 ohm should be 10k. Also, my guess is that the Dumble amp used 6L6 power tubes.
CW
CW
So you're saying a 10k instead of the 22k listed? Will update.
I'm fine with it being 6L6, I was guessing since he usually doesn't replace but reuses those old fender iron that it was likely it was 6L6 too but the schematic I took it from I thought said EL34? Or maybe I just couldn't find a 6L6 in the KiCAD symbols? I don't recall now, I'll see if I can update that.
In talking with Jelle, I think I hve the 'bright' cap done wrong on the schematic, but I put it right on the layout with a switchable bright. I've got it as a shunt instead on the schematic so I'll fix those.
Next video A quick update on the build progress...
professormudd
Those are some big-assed caps.
-Matt
It may very well be that the sole purpose of your life is only to serve as a warning to others.
A few progress photos from tonights work... of course I ran out of eyelets, need literally 8 more lol.
- ijedouglas
I can post you some if you need?pompeiisneaks wrote: ↑Tue Nov 24, 2020 5:27 am A few progress photos from tonights work... of course I ran out of eyelets, need literally 8 more lol.
Ian
I've already ordered more from mouser. They'll be here in a few days, thanks for the offer though!
If u put your tone caps direct on the pots, u will get space for your power caps direct on the board
It's all good, I'm going to buy a custom sized chassis that will be pretty big so I have tons of room. I've got fumblefingers so I want bigger/more room
The next step in the process...
Ok question. Do these look like the right transformers for a 100w Bassman build?
https://www.cedist.com/products/transfo ... 5-v-200-ma
Or should I go for their Hammond P-T290YX found here: https://www.cedist.com/products/transfo ... nder-120-v
and for output: https://www.cedist.com/products/transfo ... ent-fender the P-T1760W?
and finally choke:
https://www.cedist.com/products/choke-h ... howman-etc
and finally choke:
I'm really excited about how those caps gonna work!
Cheers
Gerhard
4A filament current looks a bit low to me on. Especially if you want to use EL34s instead of 6L6 you might be screwed...pompeiisneaks wrote: ↑Sun Dec 06, 2020 1:52 am Ok question. Do these look like the right transformers for a 100w Bassman build?
and finally choke:
Cheers
Gerhard
