Where to get D style FET board? and question about it
peckjed
Post by peckjed »
Hey all, I need to source a ODS FET board for my Brown Note D'lite - anyone know where I can purchase one?
Also, I am looking to add it to a toggle switch since the d'lite doesnt have two guitar inputs. I came across the below image (from here https://ampgarage.com/forum/viewtopic.php?f=5&t=31084) Would I be able to implement this and put the 'foot switch XLR' on a mini toggle instead? Just wondering if anyone has done this with success! Thankis.
Re: Where to get D style FET board? and question about it
peckjed wrote: Fri Nov 19, 2021 2:20 pm I am looking to add it to a toggle switch since the d'lite doesnt have two guitar inputs. ... Would I be able to implement this and put the 'foot switch XLR' on a mini toggle instead?
Sure. You don't need the relay either then? If not, see the schematic diagram (.pdf) at the link you posted above. Just replace the relay contacts with a DPDT switch and leave the level trimmer on the FET Board. Beyond that you are looking for someone to sell you a PCB? You have the option of making one, or making an eyelet board using the layout drawing. Latest version is here: https://ampgarage.com/forum/viewtopic.p ... 08#p365408
peckjed
Post by peckjed »
martin manning wrote: Fri Nov 19, 2021 3:19 pm
I got my hands on a FET board and getting ready to install it into the amp. I am having a bit of trouble wrapping my head around hooking up the FET board to a DPDT - Im not gonna lie reading schematics is not the easiest for me. Could you by chance elaborate a bit? :D
Like this. I'd mount the 1M on the switch.
peckjed
Post by peckjed »
Thank you! while im sitting here at work, I whipped up this very rough drawing. Does this seem right?
More like this...
peckjed
Post by peckjed »
ah! Thank you!!!!
peckjed
Post by peckjed »
martin manning wrote: Thu Dec 09, 2021 8:06 pm More like this...
One last question - should I be using shielded wire between the v1 and the DPDT as well as the DPDT and the input jack? or just the longer run between the DPDT and the input jack? I am planning on mounting the DPDT right in the back pretty much directly behind where the V1 is.
I would use shielded wire for any run longer than a few inches.
