PAB boost too loud on clean and virtually nothing on OD
peckjed
Post by peckjed »
Hey all! As the title says - on the clean ch the PAB is pretty drastic (sounds quite good), but when I activate the PAB with the OD ch also engaged the PAB does pretty much nothing. Is this normal? Any way to lessen the boost on clean ch?
ijedouglas
Re: PAB boost too loud on clean and virtually nothing on OD
Post by ijedouglas »
The PAB will have less of an effect dependent on the tone control settings. I also find that it has less impact between the OD and clean but it is all dependent on the drive/level and tone controls. You should still hear a difference with he OD on though. If you turn the TMB to minimum does the PAB have a bigger impact in OD?
Ian
peckjed
Post by peckjed »
ijedouglas wrote: Sat Dec 11, 2021 3:12 pm The PAB will have less of an effect dependent on the tone control settings. I also find that it has less impact between the OD and clean but it is all dependent on the drive/level and tone controls. You should still hear a difference with he OD on though. If you turn the TMB to minimum does the PAB have a bigger impact in OD?
Turning the TMB down made the PAB act as I would have expected in the OD channel. Now I feel like an idiot - thanks for the help!
