#002 Steel String Singer - almost there
Re: #002 Steel String Singer - almost there
Fantastic! I think we've all been there before... ;^)
we need a new clip!
Hey Martin,martin manning wrote: ↑Tue Mar 12, 2024 7:30 pm Fantastic! I think we've all been there before... ;^)
after some further testing, I really dig the step filter with your configuration. I mean, I have no comparison to the original one, but this is excellent for shaping the tone to different cabs/guitars etc.
The amp works really great now with my Three Musketeers - Keeley Comp+, TC Spark Booster, Nobels ODR1.
Last thing to do, FET-Boost, just to make it complete.
Cheers
Gerhard
Good to hear, Thanks! TAG now has a good guide for the mods to R Colgan's layout, and Erwin V's PCB.
Great sounds and playing there!
What have you got planned there? What FET, Vdd, and bias?
I'm not sure yet. The suggested transistors for the original FET are hard to get and expensive. There is a project in a German DIY tube amp forum called LND Boost, which is very promising.martin manning wrote: ↑Wed Mar 13, 2024 11:42 am
https://www.tube-town.net/ttstore/en/ln ... ojekt.html Cheers
Gerhard
Can you get 2N4416A? Mouser carries that one, should be fine for traditional D FET boost.
Yes but 20 bucks for the delivery. No way...martin manning wrote: ↑Wed Mar 13, 2024 2:34 pm Can you get 2N4416A? Mouser carries that one, should be fine for traditional D FET boost.
Any e-Bay sellers have them or 2N3823? You might get a few for a reasonable price.
- erwin_ve
Ill PM you on this.Lothy wrote: ↑Wed Mar 13, 2024 3:11 pmYes but 20 bucks for the delivery. No way...martin manning wrote: ↑Wed Mar 13, 2024 2:34 pm Can you get 2N4416A? Mouser carries that one, should be fine for traditional D FET boost.
I have a 12V tap left on the transformer, so I'm not bound the FET or the LND boost.martin manning wrote: ↑Wed Mar 13, 2024 11:42 am
- Raja_Kentut
look at reichelt.de… they offer some in TO-92 package, real cheap enough to try some of them if they suit your taste…
Search for „jfet“ on their site, than narrow down to „N“ type
Nothing is better than an unexpected discovery that brings you happiness!
Not quite sure what you mean there, but if you have a 12VAC source then you will need a rectifier and filtering to make that usable for a transistor boost. The Dumble JFET or the LND boost could be powered from B+5.
I think it is given, that you need a rectifier and filtering and some kind of voltage regulator. On the long run, I want the boost to be footswitchable anyway. The FET boost by it's own is not usable for me if I have to stick the cable from one input to the other. But I'll give the FET a try.martin manning wrote: ↑Wed Mar 13, 2024 4:04 pmNot quite sure what you mean there, but if you have a 12VAC source then you will need a rectifier and filtering to make that usable for a transistor boost. The Dumble JFET or the LND boost could be powered from B+5.
Cheers
Gerhard
No 2N4416A there...I can order some other types, stick them in and look what happens...Raja_Kentut wrote: ↑Wed Mar 13, 2024 4:03 pm look at reichelt.de… they offer some in TO-92 package, real cheap enough to try some of them if they suit your taste…
