Dumble SSS with Eyelet Boards and or PCBs
desertmouth90
Re: Dumble SSS with Eyelet Boards
Post by desertmouth90 »
after completion of my two Overdrive Special clone amps I am now setting forth with the construction of the SSS#002 clone.
I need to get some face plates made for this amplifier, does anyone know how to get the right fonts in AutoCad?
I have both eyelets and PCBs, im going to populate both and decided which way around ill make the amps, ie: which to retrofit into the fender twin and which to use for the scratch build.
timrobertson100
Post by timrobertson100 »
desertmouth90 wrote: ↑Fri Jun 26, 2026 10:01 am I need to get some face plates made for this amplifier, does anyone know how to get the right fonts in AutoCad?
I’m not sure how to import them, but I think Ryan has the fonts on his GitHub:
https://github.com/colganr/steel-string ... en-Artwork
desertmouth90
When I import them into Autocad its all distorted. I need my own logo on it too!
erwin_ve
Post by erwin_ve »
desertmouth90 wrote: ↑Mon Jun 29, 2026 8:47 am When I import them into Autocad its all distorted. I need my own logo on it too!
I never used autocad, Fusion360 is what I used.
When import artwork, first thing was to export the outline of the frontplate of the Sss to pdf or dxf. Then import to Inkscape. This way you have the correct dimensions to put your artwork in, Inscape also support all imported fonts needed.
When finished export the artwork to import it in autocad to verify. I'm not sure if you need seperate metal faceplates or something else like silkscreen. Both have a different route in fabrication.
desertmouth90
erwin_ve wrote: ↑Mon Jun 29, 2026 10:27 am
Thanks Erwin,
I have used Fusion before at work, but I dont have unfettered access for this. I might just make one from scratch but the text im finding hard to match the fonts.
Probably a problem for another day! ill post when I get back up and running
GAStan
Post by GAStan »
Fusion 360 has a free license for hobbiests, just limited on number of jobs that can be saved. I let mine lapse (requires annual free renual). Last time I looked it was a bit difficult to find, but it was there.
Glenn
I solder better than I play.
desertmouth90
Okay I’ll check it out! Need to get this sorted really tbh
erwin_ve
Post by erwin_ve »
What I'm saying was that you only need the dxf outline of your frontplate(export in Autocad) and do the artwork including the fonts in Inkscape. No need for Fusion360.
Afaik the front and backplate pdf is also available in the github repositories Ryan Colgan posted.
desertmouth90
Ill download it tonight
desertmouth90
Re: Dumble SSS with Eyelet Boards and or PCBs
Progress so far.
Paid for the faceplates they are underway.
Aluminium chassis is a dream to work with!
desertmouth90
Some updates, the Faceplates arrived!
Guy77
Post by Guy77 »
desertmouth90 wrote: ↑Mon Aug 10, 2026 11:28 am Some updates, the Faceplates arrived!
Congrats! Looks great.
Cheers
G
fopoman
Post by fopoman »
Amazing work!
desertmouth90
Muchas Gracias!
I need to get to test the output transformer as I suspect it only has a 4ohm secondary. I need 4.8 and 16ohm!
Will work it out when I finally get a free day.
Clive
