martin manning wrote: ↑Mon Sep 14, 2026 2:21 pm
I’m guessing the MV ground was sketchy from the start, and that was the root cause.
I thought that might be the case, but, that doesn't explain why I could control when it came on and off after I had reconnected the ground on the MV pot. Whatever it was, it's gone now
Now to try and sort out that transformer hum/vibration.
The Quadratus wrote: ↑Mon Sep 14, 2026 1:33 pm
Sorry, brother, I should have clarified. No noise, as in, no squeal or feedback. It is working absolutely perfectly.
I hate it when that happens! Makes me nervous when I think I forgot something, but it ain't broke.
Yeah, my comment could be taken either way. A good lesson on being succinct
I just had a worrying thought. Am I mismarching what my amp wants to see in terms of speakers by running my 4ohm fender twin reverb speakers on the dumble? I built the 3rd gen 50w model and since it uses both the OT and PT from a fender twin, I just assumed that I could run the fender twin speakers.
Using a hammond 290fex for PT and a 1750w for OT with only 2 6l6gc tubes... I need a higher impedance load?
Last edited by The Quadratus on Tue Sep 15, 2026 10:01 am, edited 1 time in total.
desertmouth90 wrote: ↑Tue Sep 15, 2026 8:05 am
My amp died the other night, my friend was using it haha... I think I set it up with the wrong impedance
Oh dear, sorry to hear. What symptoms were reported?
The Quadratus wrote: ↑Tue Sep 15, 2026 8:35 am
1750W is listed at 2k primary with 4 ohm secondary. 2x 6L6 need a nominal 4k primary, so you should be running an 8 ohm speaker load.
accidentally set the Impedance to 4ohm through a 16ohm cab
I reckon the valves have gone, but I hope its just a resistor or Fuse
Let's hope the iron is all good too.
It almost seems criminal that a set of 4 tubes costs as much as an OT these days. Was watching some vids on when tubes were in production back in the day, they were practically giving them away.
How on God's green earth do you know so much?
I imagine your man Matrin Manning could have taught Dumble a thing or two haha
I believe it is the valves, upon visual inspection everything looks good, no fuses gone
desertmouth90 wrote: ↑Fri Oct 09, 2026 1:07 pm
So, I have to finally admit I drilled a cabinet wrong, The chassis is too far back. despite me measuring 4 times and drilling once!
Do I just make the holes elongated? I think the ferrule washers will cover the gap.
Clive
If the washer doesnt cover it put a nice finishing machine screw in that hole and lock it from underneath with a nylon insert nut and washer, Then drill the correct hole.
