Output Level Control
JammyDodger
Post by JammyDodger »
Hey All,
I would like to be able to kick up the volume level of a #124 style amp via a pot and on/off switch. I other words... I would like a 'solo' control to boost the loudness whether the amp in is the normal or OD mode.
I'm thinking that I would like a pot to set the level and then a relay and extnal footswitch to kick it on or off.
Any thoughts?
Cheers, Mike
The Jammy Dodger
LooseChange
Re: Output Level Control
Post by LooseChange »
Add another pot in series with the master pot. Lift the ground of the original pot and place the new pot there. Set the new pot up as a rheostat. Now add a switch across the pot to bypass.
With the pot in the circuit you will get a volume jump.
heisthl
Post by heisthl »
You could just turn up the volume knob on your guitar for solos. :lol:
www.RedPlateAmps.com
