AN Wonderland/JM 100w layout
Bombacaototal
Re: AN Wonderland/JM 100w layout
Post by Bombacaototal »
M Fowler wrote: ↑Thu Sep 14, 2017 1:58 pm I can't prove it since I sold the amp but I seriously doubt I used the 250KA pot for the contour when I always use a 250KB.
I was thinking the same and was wondering what other forum members are doing on that end
Sonny ReVerb
Post by Sonny ReVerb »
I threw together a schematic of a 50w version from Taylor's layout. I'd appreciate any comments, critiques, etc.
Wunderbar_50_v1_1.pdf
(Edit to correct tube type and adopt Guy77's recommendation concerning filter caps.)
Last edited by Sonny ReVerb on Mon Oct 09, 2017 10:02 pm, edited 2 times in total.
"The blues is the roots, the rest is the fruits." - Willie Dixon
Guy77
Post by Guy77 »
I noticed you used 220uf filter caps for the power supply. I know they used that size for the 100 watt version . I used 2 100uf caps for the 50 watt version to make it not as stiff , but maybe you may prefer that. I am sure others with more experience will chime in.
Cheers
Guy
Sonny ReVerb
I prefer less filtering, as well, so I will probably do the same. Thanks.
norburybrook
Post by norburybrook »
the 1M-68k voltage divider kills too much gain for me even in a 100w amp so I'd definitely change that in a 50w. I can't remember off hand what I ended up with but I think it was maybe a 150k.
M
Sonny ReVerb
Maybe add a trim pot in line with the 68k, tweak to taste, then replace with a fixed value?
Sonny ReVerb
I think norburybrook was talking about later in the circuit? The R22 resistor sends part of the signal to ground. Using a larger resistor for R22 would send less signal to ground and maintain more (dry) signal voltage for the mixer stage.
norburybrook
Sonny ReVerb wrote: ↑Mon Oct 09, 2017 9:24 pm I think norburybrook was talking about later in the circuit? The R22 resistor sends part of the signal to ground. Using a larger resistor for R22 would send less signal to ground and maintain more (dry) signal voltage for the mixer stage.
yes, that picture is the high /low input and grid stoppers. it's the voltage divider later in the circuit that cuts a lot of gain.
Marcus
For comparison: The Ceriatone 50w JM uses 250kA contour pot and 1M-68k voltage divider.
Caps are 220uf/385 x 2 in power supply
Sonny ReVerb
amplifiednation wrote: ↑Mon Jan 09, 2017 2:15 am Some Pics - may be some slight differences.
[IMG:1280:853]http://i.imgur.com/SSmACKh.jpg[/img]
[IMG:1280:853]http://i.imgur.com/g6VlioG.jpg[/img]
[IMG:4032:1848]http://i.imgur.com/LI9pKHr.jpg[/img]
FWIW > If you check out Taylor's pics, the first two are a 100w and the larger filter caps (220uF) are longer than the smaller filter caps (22uF). In the third pic, which is a 50w, the caps are the same length (indicates to me that they are 100uF/22uF).
F&T cap dimensions:
220uF/300V - 25mm D x 49mm L
100uF/350V - 25mm D x 38mm L
22uF/500V - 18mm D x 39mm L
Bombacaototal
As far as I understand most (if not all) Fender amps have a 2 springs reverb tank. Two Rock amps use 3 springs reverb tanks, except for a few exceptions like the Matt Schofield amp which has 2.
Is it fair to assume JM Two Rock has a 3 spring tank?
Are all Dumble amps with 2 spring reverb tanks?
norburybrook
here's a bit of Jazz guitar with my 100w JM amp with an acusonics USA 1980's reverb tank.
Amp thorugh a 2x12 dumble oval backed cabinet with two vintage G12-65 celestions. No EQ or extra verb were added, this was the straight sound of the amp recorded.
https://soundcloud.com/marcus-cliffe/jazz-guitar-jm-sss
MC
Bombacaototal
norburybrook wrote: ↑Fri Nov 24, 2017 7:55 pm here's a bit of Jazz guitar with my 100w JM amp with an acusonics USA 1980's reverb tank.
MC
Firs of all this is super playing and an incredible tune.
Love the tone!! Congrats. Thanks for the info on the tank
Is your amp identical to taylor’s layout?
norburybrook
Bombacaototal wrote: ↑Fri Nov 24, 2017 8:04 pm
Amp through a 2x12 dumble oval backed cabinet with two vintage G12-65 celestions. No EQ or extra verb were added, this was the straight sound of the amp recorded.
MC
Love the tone!! Congrats. Thanks for the info on the thank
thank you :D the amp is identical except for the voltage divider (1M-68K) I think it was. i changed that as it sucked too much gain for me. I can't remember what i changed it to. If you look at my build thread it will be there
the transformers and tank came from a 1980's peavey combo. I'm not sure how many springs are in there without looking but it's a lovely clean amp with a wonderful reverb :D
I've recently done an extensive profiling of the amp/cab with my kemper and have been selling the profiles to Kemper owners :D
MC
telentubes
Post by telentubes »
Beautiful playing and tone
