Are you able to run more than one LED like this? I want to run a second LED and switch it with the unused half of the standby switch.nuke wrote: ↑Sun Sep 06, 2026 8:07 pm If for some reason you want to run an LED from the filament supply, just copy this little circuit that Fender has used for a long time across the AC heaters. D9 is just any silicon rectifier diode you have on hand. It's purpose is to shunt the reverse phase away from the LED. The reason being reverse polarity shortens the life of LED's. R56 is 150-ohms for most common type Red LED. Other colors may require a little less resistance, just depends on the color and brightness of the LED.
I've run the LED's from any handy DC supply rail, but they tend to stay on a while after the power is turned off, depending on how long the filter capacitor on that power rail takes to discharge. This particular circuit turns on and off instantly with the power mains switch.
Dumble 102 ODS
Re: Dumble 102 ODS
The Quadratus
Re: Dumble 102 ODS testing
I have a variac and a wattage/voltage/amperes readout.desertmouth90 wrote: ↑Fri Sep 04, 2026 8:13 amYou got a current limiter?
Hoping to fire it up for the first time this weekend.
Will ramp it up very, very slowly and make sure voltages etc are looking good before I go anywhere near full voltage.
But, I appreciate your concern, sir
Re: Dumble 102 ODS
Yup, since the filament supply generally capable of many amps to run the heaters, and LED's are about 10-20 milliamps each (that's 0.010 amps) you can run a heck of a lot of them like that! Just duplicate the circuit in the box for each LED and send one of the legs through the unused switch section.
I've seen builds where a string of LED's wired similarly were used to light up the whole face panel.
Re: Dumble 102 ODS
Great, thank you!nuke wrote: ↑Mon Sep 07, 2026 1:38 amYup, since the filament supply generally capable of many amps to run the heaters, and LED's are about 10-20 milliamps each (that's 0.010 amps) you can run a heck of a lot of them like that! Just duplicate the circuit in the box for each LED and send one of the legs through the unused switch section.
The Quadratus
So, just powered it up on the variac.desertmouth90 wrote: ↑Fri Sep 04, 2026 8:13 amYou got a current limiter?
Got up to about 200v AC (we run at 240vac here in Aus).
All voltages look good, slightly concerned about the heater voltage, but, I reasoned I have an artificial centre tap with 2 100ohm resistors to ground, so they are reading 3.5ish Vac.
I am concerned that I started getting somewhat of a slight hum (nothing plugged in, no tubes, all pots at 0). Verified bias pot working fine.
Should I be concerned about the hum? Sounded like transformer hum, and maybe a hum from the relays.................. Couldn't really pinpoint where it was coming from.
desertmouth90
Can you post a pic around the 100/200uf Filter caps?The Quadratus wrote: ↑Thu Sep 10, 2026 6:13 amSo, just powered it up on the variac.desertmouth90 wrote: ↑Fri Sep 04, 2026 8:13 amYou got a current limiter?
The Quadratus
Can do you one better:desertmouth90 wrote: ↑Thu Sep 10, 2026 8:19 amCan you post a pic around the 100/200uf Filter caps?The Quadratus wrote: ↑Thu Sep 10, 2026 6:13 amSo, just powered it up on the variac.
https://rumble.com/shorts/v7fbktu
desertmouth90
C17 you have two connections to Ground?The Quadratus wrote: ↑Thu Sep 10, 2026 9:38 amCan do you one better:desertmouth90 wrote: ↑Thu Sep 10, 2026 8:19 amCan you post a pic around the 100/200uf Filter caps?The Quadratus wrote: ↑Thu Sep 10, 2026 6:13 am
The Quadratus
No Sir, the thing you're seeing on the left is the jumper, and the one on the right is the actual ground wire going to ground point 2.desertmouth90 wrote: ↑Thu Sep 10, 2026 10:11 amC17 you have two connections to Ground?The Quadratus wrote: ↑Thu Sep 10, 2026 9:38 amCan do you one better:
desertmouth90
Okay, make sure you have around -50v bias voltage at the pot. Then you can fire it up with the valves in.The Quadratus wrote: ↑Thu Sep 10, 2026 9:38 amCan do you one better:desertmouth90 wrote: ↑Thu Sep 10, 2026 8:19 amCan you post a pic around the 100/200uf Filter caps?The Quadratus wrote: ↑Thu Sep 10, 2026 6:13 am
Are all your voltages good?
The Quadratus
I am assuming none of the ones you built Vibrate/hum?desertmouth90 wrote: ↑Thu Sep 10, 2026 10:38 amOkay, make sure you have around -50v bias voltage at the pot. Then you can fire it up with the valves in.The Quadratus wrote: ↑Thu Sep 10, 2026 9:38 amCan do you one better:
So, I only worked up to 200Vac, and the voltages at pin 6/4 on the power tubes were around 304, voltage at pin 5 was around -40.
was seeing roughly 10v at the voltage doubler section, so, voltages were correlating nicely according to the voltage I was feeding the thing.
I had nothing plugged in, no tubes, no cables. Was reading 20.5ish mAmps across the AC input, but when I noticed the hum/vibration the Amp reading was jumping a bit from mid/high 20mAmps to low 30mAmps, it was a bit erratic.
I then decided to power it down and try to think about what could be potentially causing it. I know transformers can hum/vibrate, it is a thing, but, am unsure if that is what is going on here.
Tubes arrive tomorrow. Then, have to figure out how to bias the PI
Edit: Voltages at pin 3 of the power tubes was also reading correctly for the voltage I was feeding it.
desertmouth90
The Quadratus wrote: ↑Thu Sep 10, 2026 10:49 amI am assuming none of the ones you built Vibrate/hum?desertmouth90 wrote: ↑Thu Sep 10, 2026 10:38 amOkay, make sure you have around -50v bias voltage at the pot. Then you can fire it up with the valves in.The Quadratus wrote: ↑Thu Sep 10, 2026 9:38 am
Are all your voltages good?![]()
The 100w one I did yes, I friend 4 JJs too. Thats when I realised I wired the Bias pot wrong!
Do you have a dummy load on the OT?
Id try 240v, not much difference between 200v and 240v (I know its nerve racking).
The Quadratus
I do not have a dummy load on the OT. I found out that I did not need one if no tubes are plugged in. (wired my 1975 Fender Twin and got everything up and running without tubes and no load when checking my work and only plugged in the speaker when I plugged in the tubes for power up and biasing)desertmouth90 wrote: ↑Thu Sep 10, 2026 10:55 amThe Quadratus wrote: ↑Thu Sep 10, 2026 10:49 amI am assuming none of the ones you built Vibrate/hum?desertmouth90 wrote: ↑Thu Sep 10, 2026 10:38 am
And, yes, it is bloody nerve wracking. Bloody jumped at any little noise that happened, whether it came from the direction of the amp or not
Any suggestions on where/how to get a decent dummy load?
desertmouth90
Yeah you make a good point!The Quadratus wrote: ↑Thu Sep 10, 2026 10:59 amI do not have a dummy load on the OT. I found out that I did not need one if no tubes are plugged in. (wired my 1975 Fender Twin and got everything up and running without tubes and no load when checking my work and only plugged in the speaker when I plugged in the tubes for power up and biasing)desertmouth90 wrote: ↑Thu Sep 10, 2026 10:55 amThe Quadratus wrote: ↑Thu Sep 10, 2026 10:49 am
I am assuming none of the ones you built Vibrate/hum?![]()
And, yes, it is bloody nerve wracking. Bloody jumped at any little noise that happened, whether it came from the direction of the amp or not![]()
With your Control grid stoppers what values do you have?
I made a mistake of using 5.1ohm instead of 5.1k resistors before. Just double check that.
You can build one using 50/100w Wire wound resistors, Or use a load box, or you can use a speaker.
is the hum your power transformer?
The Quadratus
My grid stoppers are 5.1kOhm. Just double checked to make certain of it.desertmouth90 wrote: ↑Thu Sep 10, 2026 11:12 amYeah you make a good point!The Quadratus wrote: ↑Thu Sep 10, 2026 10:59 amdesertmouth90 wrote: ↑Thu Sep 10, 2026 10:55 am
I think it might be one of the transformers, but, can't tell. I put my ear close to the underside of the chassis, and couldn't tell if it was coming from there or from inside the chassis.
I guess we bias it up and see what happens, if anything.
Going to plug in my Fender twin reverb speakers as they are 4ohm and I have the identical fender twin Hammond OT.
