Today you choose.... FORD's or TAG's
Locked
dogears
Re: Today you choose.... FORD's or TAG's
Post by dogears »
Yes. I recorded that with my video camera and mic setup. Pinner (member here) playing.
Mac Daddy
Post by Mac Daddy »
Yes
Thanks Shad. :)
dogears
Post by dogears »
Two 330uf caps in series. Actually measured about 300uf each fwiw.
So, a typo....
Structo wrote:WOW! :shock:
Thanks a lot Shad! :D
Are you serious about 330uF paralleled for B+?
So 660uF total for plates?
Or did you mean series and 165uF total?
I figured in his excitement he meant series. :lol:
What does TKT mean?
67plexi
Post by 67plexi »
Shad, Thank you for your generosity of information on the RF & Tag Amps.
Steve.
bluesfendermanblues
Post by bluesfendermanblues »
Shad and you'all
This has turned into a very exiting threds already :D
I'm heating up my soldering iron to modify those amps tonight 8)
Thanks for sharing this info Shad.
bigmik
Post by bigmik »
I'm guessing TAG KNOWS TONE :D
Structo wrote:I figured in his excitement he meant series. :lol:
What does TKT mean?
dimitris
Post by dimitris »
Thanks Shad for all that info.
Sometime ago it was posted at ceriatone forum that RF's amp has no V2A snubber and V2B coupling cap is 0.01uf .Can anyone confirm if that's really the case?
ampdork
Post by ampdork »
Sorry yes series wiring.... I was speaking physically... ;O)
TKT amp
6ps .05 coupler V1-b
715 .015 V2-a
6ps .05 OTG's
Dropping string 3K, 22k, 2k2
"...& I'm all out of bubblegum"
dogears
Post by dogears »
No.... Not the case, it has snubbers. Shad posted the amp specs of a Bludo Ojai. Regular cap arrangement in OD. .05, .01, .005
dimitris wrote:Thanks Shad for all that info.
dogears
Post by dogears »
Thanks Shad!! So that big boy is a 715. Sucker is huge!
ampdork wrote:Sorry yes series wiring.... I was speaking physically... ;O)
TKT amp
715 .015 V2-a
6ps .05 OTG's
ampdork
Post by ampdork »
Question, was the OD trimmer measured with the amp on and OD on?? The reading changes depending on whether the amp is on and OD engaged.....
My notes indicate that I was getting 33K from the node of the trim pot and 220K and the wiper and 21.53 from ground. notes say OD IN...
[/quote]
ampdork
Post by ampdork »
Also, didn't 183 have some larger OD1 cap?? .05uf on OD1. Pretty important fact.
If in fact it were a fact...
Notes say .015 OD1
dogears
Post by dogears »
Interesting, the pics say it is a 100K trimmer. So, wouldn't you get 100K from trimmer input to ground? Unless the OD was not on, then the 220K is grounded on the other side....
In my tests, a setting of about 24K sounds best.... From wiper to ground. Fwiw of course.
[/quote]
Locked
