Thanks for the welcome!Luthierwnc wrote:Welcome to TAG.
This is probably a good time to talk about speakers. Conventional wisdom splits down the middle. One branch likes heavy, cast-frame American drivers like the EVM12L (or S), Altec 417 and some of the Eminence line. The other branch favors Celestions -- particularly the G12-65 or Scumbacks/WGS speakers from that lineage.
Me; I have a set of both and would hate to have to choose permanently.
Spend some time researching the speakers and cabs that work for the sound in your head. There are a lot of 183 clips on YouTube. Many of them describe the box under the head.
Also keep in mind these amps don't favor all guitars equally. Strats don't get a lot of love with the later generations of the ODS. The 183 is towards the end of that line. At least, a lot of us try once and then get a Tele or something with buckers.
The last thing to add to your to-do list is whether you've considered whether building a matching active loop. It is a one-tube FX circuit that adds a lot to the sound whether you actually use it for effects or not. The jury is out as to whether you must have one but it you have one resistor left in the bin when you finish the amp, you'll need to do something with it, right?
Skip
I have an 1963 Epiphone E230TD Casino I play. I hope that works? The finish got moisture damage (nitrocellulose doesn't like H2O) I haven't figured out how to rectify. It looks like it's just the clear coat. The red is still apparent. It has a P90 neck and a retrofit humbucker at the bridge.
and how did you know I have one resistor left? It's a 47 ohm. I scoured the scheme and it's nowhere on there! Not sure where it goes.
Sounds like you're describing the Dumbleator?
Speakers is a great subject. I'll check out the youtube clips.
I ripped two 12's out of a SUNN half stack my brother gave me. They've been stored in the basement for 20 years or so? I might give one of those a try, though I'm not sure they can handle a Dumble clone? They're 60w rms each.
see pics
My plan was to make this a head, then a single 12 cabinet in the Dumble style to split up the weight issue.
