100w 2nd Gen. ODS build
Re: 100w 2nd Gen. ODS build
DSull89 wrote: ↑Tue Aug 29, 2023 12:57 am...I'm gonna have to make my own board templates as the mounting centers are a little weird. (the preamp board mounting centers are 7 3/16" x 2 7/16"). My plan is just to size the boards based on the mounting holes and was wondering if anybody knew what the distance from eyelet to board edge was? Would 1/4" suffice?
Depends on the size of the board mounting hardware. I would not like to see the corners of a hex nut extend beyond the edge of the board, so I would say the edge-to-edge dimension should be at least the mounting bolt dimension (c-c) + 2 x (Hex nut size across flats / 1.7)
DSull89
Post by DSull89 »
Thanks for the input, Ian and Martin! Will definitely help! :)
-Dan
frusciante89
Post by frusciante89 »
FYI, you can still use the PCB for the second generation. I've designed it to be compatible with 102, 124, 183 and 3rd gen models, and the 2nd gen is relatively similar to the 3rd.
Of course, you might need to additional chassis drilling but apart from that you should be good to go! :)
Andrea
AA Electronics
DSull89
Post by DSull89 »
Thanks for the info, Andrea! I decided to go with making the individual boards myself for the added challenge and for the sake of originality, but I was definitely impressed with the quality of your boards! Nice work! Plus it gives me a good excuse to use your board to build another amp down the road. :)
-Dan
DSull89
Post by DSull89 »
So I was wondering if anyone could recommend what value can cap to use here since this chassis is not set up to mount the 20uf filter that’s normally at the rear by V1?
ijedouglas
Post by ijedouglas »
DSull89 wrote: ↑Tue Sep 05, 2023 11:36 pm So I was wondering if anyone could recommend what value can cap to use here since this chassis is not set up to mount the 20uf filter that’s normally at the rear by V1?
Just put 4 x 20uf caps on the power board and you should be good to go.
Ian
DSull89
Post by DSull89 »
Thanks, Ian! Great idea! I think I’ll do just that! :)
DSull89
Post by DSull89 »
Another little update. I went with Reggie at RawCabs for my head cab and had him do a straight front 1st/2nd Gen. style. He does really nice work!
jabguit
Post by jabguit »
DSull89 wrote: ↑Wed Sep 13, 2023 5:23 pm Another little update. I went with Reggie at RawCabs for my head cab and had him do a straight front 1st/2nd Gen. style. He does really nice work!
Reggie does great work - and is great guy to boot.
cheers,
Jack Briggs
Briggs Guitars
DSull89
Post by DSull89 »
He most certainly does and is! Extremely thorough, too. Takes a lot of pride in his work and really goes out of his way to make sure you get a perfect cab. :)
frusciante89
DSull89 wrote: ↑Fri Jul 14, 2023 1:51 am Great! Thanks for the input! I have a transformer I bought when I was planning on building #102. I actually bought a pcb from AA Electronics but I’m not sure it will work for a 2nd Gen. build. Did the circuit layout change much from 2nd generation to 3rd generation on the ODS or was it just the component values within the same format? Here’s a picture of the pcb. Would I just be better off going for the eyelet boards instead?
Hello, I'm the builder of the that Dumble PCB :) Late answer, but just wanting to confirm that the board does work with the 2nd gen! Check the layouts at the resource page of my website: https://www.aaelectronicspcb.com/resources
Hope the build is going great!
Andrea
AA Electronics
DSull89
Post by DSull89 »
Took a while to finally get this under way, but I’ve begun wiring up the boards for this build. Let me know if there are any glaring mistakes. Also wanted to ask about the 100Ω resistor for the control bus ground. Jelle sent me a couple substitutions for the 100Ω resistors in this circuit and supplied me with one 90Ω and three 150Ω. Any suggestions? All advice is much appreciated. :)
Thanks,
Dan
ijedouglas
DSull89 wrote: ↑Thu Feb 20, 2025 1:22 am Took a while to finally get this under way, but I’ve begun wiring up the boards for this build. Let me know if there are any glaring mistakes. Also wanted to ask about the 100Ω resistor for the control bus ground. Jelle sent me a couple substitutions for the 100Ω resistors in this circuit and supplied me with one 90Ω and three 150Ω. Any suggestions? All advice is much appreciated. :)
Thanks,
Dan
Hi Dan, what do you want to know about the control ground bus? As far as I know, the bus should go directly to ground and there is no 100R resistor. The 100R resistor is typically used as a pair on the heater wires as an artificial center tap.
Ian
DSull89
Post by DSull89 »
Hi Ian! I was referring to this, I guess I misinterpreted the topology.
ijedouglas
DSull89 wrote: ↑Thu Feb 20, 2025 2:15 am Hi Ian! I was referring to this, I guess I misinterpreted the topology.
Got it, that is the Accent/NFB shunt resistor. I haven't tried different values in there but from what I recall those that did recommended sticking to the Dumble value. You can always try the 90R and 150R and see what happens.
Ian
