Dingleberry wrote:That's an astonishing job you have done ic-racer!
I had empty chassis and transformers for 2xEL34 project so I couldn't help myself...
Power supply wiring is nearly completed.
-T
Is this going to be another Manzamp? How are you going to do the main board? Eyelet board? Do you know how to etch copper boards? Do you want a pattern?
Not an exact clone but very "Manzampish" with just some minor tweaks so I can use those parts I have on hand. Chassis and transformers have waited about two years for suitable build. Now I have some spare time and finally I have decided what to build;)
I'll be using diode bridge because my PT didn't have neither 5V winding nor center tap. B+ should be very close to 430V.
And probably I wire the first triode parallel and keep just one volume so I don't have to drill any new holes to front panel. I like to keep the original aesthetics with old donor amps if possible.
And I don't have the cathode bypass inductor, but that I can figure out somehow.
I've etched boards before, but I think I wire this point to point. There ain't many components inside. Probably use only terminal strips because I have some on hand. Usually I design the layout on the fly when I play with terminal strips and with this kind of salvaged donor amps.
I'll keep you in touch when I gain some progress with that build.
-T
Thanks for posting that. So, there are a number of ways one might incorporate the choke. The active tone circuit I posted used a 22Hy (not mHy!) choke. The circuit I came up with is 3Hy (not 3mHy!) so there are some big differences. A lot of room for experimentation on this.
"You feel like you're floating on a football field filled with marshmallows." -Dumble
Here is another example of a choke on the cathode of a preamp tube that I used in my research. This one is the distortion circuit from the Fender Super Twin Reverb.
LeftyStrat wrote:At 3Hy and 25uf, the resonant frequency should be at 18hz.
How sure are you about the value of the cap?
Just a guess based on the size and presumed voltage of the cap in the picture and cap value in the Thordarson circuit.
The other point that I want to share is that the circuit research on this amp involved more of a 'cut and paste' from other known working circuits (Skyliner tone, Precision Power, etc) rather than any new circuit engineering on my part.
That's an interesting design. Here's the Ampeg V9 preamp with three different inductors to switch the range. The V4 used a tapped 800mH inductor with taps at 300mH and 100mH. Note that this schematic incorrectly labels them micro henries.
So far the Manzamp is sounding good with every guitar I have tried. Here it is with my new-to-me ES 335 (1997).
Still have 19 guitars to try.... http://www.youtube.com/watch?v=0D81FMc6Dc4
ic-racer wrote:So far the Manzamp is sounding good with every guitar I have tried. Here it is with my new-to-me ES 335 (1997).
I really love the bass response on the amp. Very throaty, even with the strat. No hint of woofyness.
As I come up on 24 hours with this completed amp it seems as if I am incredibly lucky to have it sound so good. In reality, I think that 90% of the good sound of this amp is from the 'known' elements. That is, the Skyliner tone, Precision Power, phase inverter and known 5f6a elements.
I think the 'unknowns' probably contribute only 10% of the overall tone.
