Violeta - a single Ended Story
markusw
Re: Violeta - a single Ended Story
Post by markusw »
Thanks for sharing!
Great sound and playing! 8)
Do you have more clips?
May I ask one question: is it really 2-4 µF (not nF?) from EL84 Anode to gnd?
Peace,
Markus
hywelg
Post by hywelg »
This is really interesting. I had been hoping that something like this would come along, but had just about given up. I was intending to get one of these
http://www.ampmaker.com/store/Double-Si ... ifier.html
and had been thinking about how to add in an o/d section.
Since I'm not terribly knowledgeable about things electronic, and I've only ever built kits, a scratch build is probably beyond my abilities, but I think I could just about manage to do something like this especially if I could use the output section of the Double Six kit.
honeydip
Post by honeydip »
Markus, you are right it's 2 to 4nF depending on your Taste.
Thank you for the correction.
At the moment I don't have more Clips available. What are you interested in?
@10thTx: could you correct the schematics accordingly?
Thanks in Advance.
Honeydip
No distortion means to tone.
stiltamp
Post by stiltamp »
Thank you for the information.
The PT I have taken out of an old Radio
How much is the secondary HT Voltage value of it?
markusw
Post by markusw »
honeydip wrote:Markus, you are right it's 2 to 4nF depending on your Taste.
Honeydip
If you happen to have the chance to record a clip with Strat that would be great. :)
One more question: how do you like the tone control of the clean channel when in OD?
Thanks again for sharing your work!
Regards,
Markus
2-4µF on the cap on the EL84 plate to ground.
10thTx
Post by 10thTx »
What does that mean?
Per earlier post request, ............... I already changed the schematic to reflect a .002-.004 cap from EL84 plate to ground?
What should it be?
With respect, 10thtx
honeydip
Post by honeydip »
I'm sorry, you are right and I was blind :shock:
The schematic is correct.
Thank you.
Honeydip
10thTx
Post by 10thTx »
I am understanding this to be that the currently posted schematic is correct? I changed it to the current one after you requested me to do so.
Just post a reply if it needs to be changed from the current schematic, otherwise, I will presume it is currently correct.
Thanks, 10thtx
Oh Snap!
Sorry my bad, I missed the n part on the 2-4
Which translates to .002-.004µF
Us Yanks aren't used to nano farads so much as micro and pico.
wicker
Post by wicker »
Structo wrote:Us Yanks aren't used to nano farads so much as micro and pico.
I've noticed that, I always did not understood why the hell, instead od 0.1u couldn't be 100n :D
Paul
boldaslove6789
Post by boldaslove6789 »
Sounds Great!!
alvarezh
Post by alvarezh »
Nice sounding little amp, thanks for sharing. Thank you 10thtx for the drawings.
A couple of points of interest on the drawings:
1) I do not see the 220k/500pF that stands between the volume wiper and grid (pin 7) of V1b on the layout. It's on the amp's picture so it should be there.
2) The trim pot entrance value to V2a grid (pin 2) is shown as 100k on the schematic, it's 220k on the layout. Which is correct?
Thanks in advance.
Horacio
Play in tune and B#!
10thTx
Post by 10thTx »
Go with the schematic which should be correct.
100k trim pot
220k/500p can be placed on the volume pot wiper or on the tube socket V1-7.
I don't actually plan on building this amp even though it's a great amp. I simply tried posting a schematic that was easier for others to read.
alvarezh
Post by alvarezh »
Thank you for clarifying 10thtx, and thanks again for taking your time to make the drawings.
All the best.
Horacio
