New 183 build
Stephen1966
- ijedouglas
Re: New 183 build
I'll probably keep the cab and just have the tolex redoneStephen1966 wrote: ↑Fri Sep 23, 2022 8:45 am That looks great. The Marshall logo is in one piece at least. Will you put it in a new cab?
Ian
Re: New 183 build
tube town is reading here!
Re: New 183 build
more offtopic
inside are sozo caps, cheap carbon films, and some metal oxide in cathodes.. You can find JTM build guide to check what they put inside...
I never liked Marshall amp with orange drops, so if you put orange drops inside 183, try to change them for sozo, it is cheaper than new OPT..also treble caps put all ceramic this can help in highs..
Stephen1966
Re: New 183 build
If it's particle board - so damn heavy and it absorbs water like a sponge. When you get the tolex off you will see if it has accumulated any water damage. That logo has aged beautifully though. And I bet it sounds amazing!ijedouglas wrote: ↑Fri Sep 23, 2022 12:52 pmI'll probably keep the cab and just have the tolex redoneStephen1966 wrote: ↑Fri Sep 23, 2022 8:45 am That looks great. The Marshall logo is in one piece at least. Will you put it in a new cab?
Stephen
www.primatone.eu
www.primatone.eu
Stephen1966
Re: New 183 build
I beg to differ, quite on-topic actually. Good ideas and a lot easier to audition.bepone wrote: ↑Fri Sep 23, 2022 1:03 pmmore offtopic. i have JTM Metroamp with Mercury inside, and i like it a lot. Has this grinding middle,
MM transformers though! Horribly over-priced!
Stephen
www.primatone.eu
www.primatone.eu
WhopperPlate
Re: New 183 build
For grinding Marshall mids I tend to throw a carbon composition somewhere in the B+ line . I always liked how Marshall did this : often times early part of the string is CC and later CF. I feel this keeps things tight but relaxed at the same time .
Charlie
jazzbass
Re: New 183 build
Hi,
I built a # 183 with two EL34 Millards which sounded very good. But I never liked the sound of that amplifier.
The clean was not bad but the OD was bad.
I turned it into Bluesmaster and it sounds fabulous. The AAElectronic mother board helped me a lot as it withstood all the torment of unsoldering and soldering new components and then the adjustments of the same and then, of course, other soldering.
The PT, OT, and choke transformers were built by an Italian manufacturer based on Marshall specifications.
A hug
Franco
A hug
Franco
franco mezzalira
WhopperPlate
Re: New 183 build
One time I was troubleshooting an intermittent issue in an amplifier , and subsequently replaced a preamp tube micalex style socket with some old ceramic I had in the stash. (Like your 183 above)
I wasn’t trying to listen for a difference, but that amplifier became suddenly a tad abrasive and harsh, especially in OD.
I solved the problem , but after scratching my head on the sound I realized the only variable I wasn’t considering . New micalex socket was installed and all the edges rounded off….
I mention this because that was also an el34 Marshall type amp … fwiw … those type of tubes and iron can really bring out the midrange detail …
Charlie
Stephen1966
Re: New 183 build
That's interesting! I notice in the photo I am looking at here, Q-lines are used in the PS. I am thinking CF for that as well. The balance resistors look like ordinary Dralorics.WhopperPlate wrote: ↑Fri Sep 23, 2022 3:47 pm For grinding Marshall mids I tend to throw a carbon composition somewhere in the B+ line . I always liked how Marshall did this : often times early part of the string is CC and later CF. I feel this keeps things tight but relaxed at the same time .
Stephen
www.primatone.eu
www.primatone.eu
WhopperPlate
Re: New 183 build
Stephen1966 wrote: ↑Fri Sep 23, 2022 4:09 pmThat's interesting! I notice in the photo I am looking at here, Q-lines are used in the PS. I am thinking CF for that as well. The balance resistors look like ordinary Dralorics.WhopperPlate wrote: ↑Fri Sep 23, 2022 3:47 pm For grinding Marshall mids I tend to throw a carbon composition somewhere in the B+ line . I always liked how Marshall did this : often times early part of the string is CC and later CF. I feel this keeps things tight but relaxed at the same time .
What photos are you referencing?
Charlie
Stephen1966
Re: New 183 build
Hi Franco, who was the manufacturer? Interesting to hear!jazzbass wrote: ↑Fri Sep 23, 2022 3:48 pm Hi,
A hug
Franco
Stephen
www.primatone.eu
www.primatone.eu
Stephen1966
Re: New 183 build
These: https://ampgarage.com/forum/viewtopic.p ... 39#p443539WhopperPlate wrote: ↑Fri Sep 23, 2022 4:13 pmStephen1966 wrote: ↑Fri Sep 23, 2022 4:09 pmThat's interesting! I notice in the photo I am looking at here, Q-lines are used in the PS. I am thinking CF for that as well. The balance resistors look like ordinary Dralorics.WhopperPlate wrote: ↑Fri Sep 23, 2022 3:47 pm For grinding Marshall mids I tend to throw a carbon composition somewhere in the B+ line . I always liked how Marshall did this : often times early part of the string is CC and later CF. I feel this keeps things tight but relaxed at the same time .
Stephen
www.primatone.eu
www.primatone.eu
WhopperPlate
Re: New 183 build
All CF dropping Rs is my second favorite arrangement . Brand dependent of course .Stephen1966 wrote: ↑Fri Sep 23, 2022 4:32 pmThese: https://ampgarage.com/forum/viewtopic.p ... 39#p443539WhopperPlate wrote: ↑Fri Sep 23, 2022 4:13 pmStephen1966 wrote: ↑Fri Sep 23, 2022 4:09 pm
Charlie
Stephen1966
Re: New 183 build
Understood. The goal here is to find commercially available, in production components. Nothing against the exotic of course, except they are often unsustainable, usually quite over-priced and (quite likely) offer intangible benefits over current production runs. There may even be superior modern equivalents. Don't want to dig up a repeat of a conversation that's been going on elsewhere in this forum but please, pray tell... what is your secret sauce ?WhopperPlate wrote: ↑Fri Sep 23, 2022 4:41 pm All CF dropping Rs is my second favorite arrangement . Brand dependent of course .
Stephen
www.primatone.eu
www.primatone.eu
